Hotmail rejecting mail from PN [Diagnostic-Code: smtp; 550 5.7.1]
- Re: Hotmail rejecting mail from PN [Diagnostic-Cod...
Re: Hotmail rejecting mail from PN [Diagnostic-Code: smtp; 550 5.7.1]
a month ago
Replying to whoever above me but I just tried to send an email to someone with a hotmail account and got the dreaded
Diagnostic-Code: smtp; 550 5.7.1 Unfortunately, messages from [212.159.14.XX] weren't sent. Please contact your Internet service provider since part of their network is on our block list (S3140).
(Removed part of IP just in case).
This has been going on for MONTHS now intermittently? I've mentioned it myself on the forum and there have been so many othe compalints.. Can it just not be solved? ![]()
a month ago
a month ago
A closing note from me, the OP of this topic. If you read the post before this one you will see that I've given up on PN email.
I'm still in the process of letting my contacts know of my change of email address, and am likely to doing that for a while yet, but it's worth all that hassle to once again have an email system that works without error.
a month ago - last edited a month ago
@stuck wrote:
@MisterW Sending to Outlook is still broken:
Diagnostic-Code: smtp; 550 5.7.1 Unfortunately, messages from [84.93.230.227] weren't sent. Please contact your Internet service provider since part of their network is on our block list (S3150)
Any chance you can poke someone to get more details?
"BT" 😊
Perhaps the question is (or should be?): Who is in charge here?
If not Greenby (IMO it frequently isn't), then Plusnet or BT?
4 weeks ago
@stuck wrote:
@plusnettony, @Townman, @MisterW
Shame to see you move emails. but there has been vast improvement of late in sending to Hotmail.
4 weeks ago
Plusnet responsible for outbound email (currently).
4 weeks ago - last edited 4 weeks ago
Also, what are the settings inc ports for 3rd party email clients as there seems to be various sources from both plusnet and greenby that differ for the same plusnet brand. A link to which page has the definative details would be great.
Here is a line from an email I sent to myself at a BT Email account from my Greenby account via webmail;
Received: from kayla.gateway.enmail.co (91.204.211.108) by btprdrgi023.btinternet.com
It was classified by the BT Email system as "Spam". 🙂
X-RazorGate-Vade-Verdict: spam 107
X-RazorGate-Vade-Classification: commercial-dirty
I don't use client email software, only Greenby Webmail. However, the current setting are given online at the Greenby Portal and are:
Email Client Settings
Incoming Server Address imap.plus.net
Protocol IMAP
IMAP Port 993 (Encryption Enabled)
Outgoing Server Address relay.plus.net
SMTP Port 465 (Encryption Enabled)
If you prefer to use the POP protocol rather than IMAP then please use port 995 with Encryption turned on
If I were using client software I would stick to using the above settings which are found on the Emil/Settings page of the Greenby User portal. Many variations of the above have been given in the past by Plusnet and by posters on this forum. If I were using such software the above are the settings I would stick to. They also align with the recommended settings for client email software given by Cloudflare:
Cloudflare
What SMTP port should be used? Port 25, 587, or 465?
https://www.cloudflare.com/en-gb/learning/email-security/smtp-port-25-587/
4 weeks ago
@plusnettony Re #230 and #231
So when are the problems sending to gmail and Apple addresses going to be solved?
4 weeks ago
Appreciate that is what one page on greenby says but elsewhere on greenby it lists different ports & servers. Searches for results on plusnet pages comes back with similar variances hence my request from plusnet staff for definative link that we can all point other forum members to
4 weeks ago
@plusnettony wrote:
...there has been vast improvement of late in sending to Hotmail.
There has? Can't say I've noticed.
3 weeks ago
Improvement is in the eyes of the beholder.
3 weeks ago
The problem is that 212.159.14.17 translates to avasout-peh-002. This domain name appears on several blacklists. This is not surprising since relay.plus.net is an open relay and anyone can use it, including spammers, which is why servers such a hotmail won't accept mail from it. The solution is for plus.net to create a separate relay host which requires only plus.net account holders to use with password access. Open relays are a bad thing - plus.net should not host one.
JMN
3 weeks ago
I'm getting the same problem. I can't even email my own wife without getting it returned to me with an error message:
Diagnostic-Code: smtp; 550 5.7.1 Unfortunately, messages from [212.159.14.20] weren't sent. Please contact your Internet service provider since part of their network is on our block list (S3150). You can also refer your provider to http://mail.live.com/mail/troubleshooting.aspx#errors. [Name=Protocol Filter Agent][AGT=PFA][MxId=11BD4E59647EC38F] [SA2PEPF00003F65.namprd04.prod.outlook.com 2026-05-05T15:15:38.345Z 08DEA72CB5F8BE19]
3 weeks ago
