Hotmail blocked
microfinch
Hotmail blocked
Hi there. I'm replying to a message from a hotmail account with a hotmail account and it's getting blocked:
550 5.7.1 Unfortunately, messages from [89.187.86.92] weren't sent.
Please contact your Internet service provider since part of their network is on our block list (S3150). You can also refer your provider to http://mail.live.com/mail/troubleshooting.aspx#errors.
[DB3EUR04FT012.eop-eur04.prod.protection.outlook.com]
haven't got time to wait on the phone to support!
thank you.
mike
Tags (1)
6 REPLIES 6
Fixes: 585
Re: Hotmail blocked
Yet another instance of incorrect use of the Spamhaus PB by outlook mail servers
From here https://www.spamhaus.org/faq/section/ISP%20Spam%20Issues
Should an ISP use the PBL to block their own users?
  No! Spurious blocking caused by sites using the Spamhaus PBL to block authenticated access to smarthosts or outgoing email servers is very bad. The PBL is only designed to be used on incoming email, i.e. on the hosts that your MX records point to.
If you use the same hosts for incoming email and smarthosting or outgoing email, then you should always ensure that you exempt authenticated clients from PBL checks. As your users are often on dynamic IP addresses, a user may be assigned an IP address from his provider that is in the PBL.
Another way of putting this is: "Do not use the PBL to block your own users".
Note: This also applies to using the PBL to deny access to web-forums, journals or blogs.
microfinch
Re: Hotmail blocked
hmmm. thanks very much. but not sure that's solving the issue?! i'm on a fixed IP anyway.
Fixes: 585
Re: Hotmail blocked
that IP listed is NOT a PlusNet IP, Its out1-typhoon.hostingseries.net.
Are you sending via another ISP mail server ?
microfinch
Re: Hotmail blocked
it's another domain provider. would it be best to use a plusnet mailserver for a domain that hosted elsewhere? not sure that'd work. or just sort it out with spamhaus? or get the domain host to sort it out?!!
Fixes: 585
Re: Hotmail blocked
that would be best
That will work providing you can change the SPF record for the domain, to include the plusnet mail srrvers
microfinch
Re: Hotmail blocked
yes, domain host fixed it. thanks very much for your help.
Mike
