Greenby migration and Thunderbird
Bwhitnall
After a few days of trial and error I have now succeeded in using Thunderbird to access my primary plusnet email account.
Prior to the migration I had two plusnet email accounts in the format
[email protected]
[email protected]
I accessed my husband email account via three routes:
Thunderbird 140.6.0esr (32-bit) under Windows 10, imap
iPhone 7, imap
Outlook Express under Windows XP, pop3
The mail is set to clear off the server after a month, so only the pop3 account contains a full email history.
After migration iPhone and Outlook express still worked fine (except for duplication of pre migration emails in Outlook Express).  However Thunderbird would not login to the server.
I did manage to login to Greenby, but had to use email address in the format
[email protected]
I discovered my wife's email did work ok with Thunderbird  after migration still using [email protected]
So I changed my Thunderbird server setting to
User Name : [email protected]  (had been  [email protected])
Port: 143
Connection security : None
Authentication method: Password, transmitted insecurely
No changes made to Outgoing Server settings
THUNDERBIRD NOW WORKS.
I would welcome suggestions on alternative, more secure, options for Connection security and Authentication method
1 REPLY 1
mavison
Re: Greenby migration and Thunderbird
My Thunderbird IMAP server is set to imap.force9.net, port: 993, security: SSL/TLS, Authentication: Normal password.
That encrypts emails to the server, which your settings do not.
I also have a User Name of just my account name for the main mailbox.
These were unchanged from my Plusnet (Force9) settings before migration.
