Greenby emails not working - Receive YES - Send NO
computersupport
Re: Greenby emails not working - Receive YES - Send NO
** Issue resolved for customer **
I do IT support and had the same issue regarding sending / receiving. The customer changed their password somewhere and things stopped working.
To be clear here, this customer (and presumably everyone now migrated to Greenby) has TWO different accounts:
* Plusnet / account management user
* EMAIL account
Both accounts can have different passwords.
The customer was using their Account password to login to their email, and I found that I could gain access to recieve their email (but not send) using their Email password.
Resolution:
* Incoming email set to EMAIL password, SSL on
* Outgoing email - and here's the ridiculous thing - using their PLUSNET ACCOUNT password, on PORT 465, SSL on
Yes, that's right, the outgoing password was working when I used their Plusnet account password rather than their Greenby email password. This worked on IOS (iphone/ipad) mail app, and also on Outlook 2010 (!)
Have a go and see if the above works for you.
pvmb
All Star
Fixes: 14
@computersupport
"To be clear here, this customer (and presumably everyone now migrated to Greenby) has TWO different accounts:
* EMAIL account
Both accounts can have different passwords."
By "EMAIL account" here do you mean their migrated Greenby user management account, via the Greenby.com portal and hence, I presume, subsequent log on to the Greenby webmail interface (I don't use device based client email)?
The current situation is that outgoing SMTP emails are going via relay.plus.net [212.159.8.107], presumably needing Plusnet credentials.
The 'official' incoming mail host is, according to Greenby, imap.plus.net  [91.204.208.26] which one might expect to also need Plusnet credentials, however it is in a Greenby domain. Some are now using mail.plusnet.enmail.co [91.204.208.26] or mail.enmail.co [91.204.208.195], which are all in Greenby domains.
I suspect some people may have been changing their passwords to solve 'issues' which may, in some cases, just be mistakes or misunderstandings and this - along with current situation of incoming and outgoing mail hosts being in two different domains - is behind these matters.
However, I could be talking nonsense!
computersupport
@pvmb
It was a few days ago and I didn't note everything down, but I recall logging in to the Plusnet account management also allowed me to log into possibly a Greenby management page (yes her email has migrated) - and there was a list of email addresses somewhere, with just the one address listed (presumably you can have / pay for more than one email address under the same account). From there you may be able to change a password for an individual email address? Could there end up being *three* accounts - plusnet, greenby, greenby email?Huh
I used imap.plus.net and relay.plus.net.
So I guess it's always possible that the outgoing will change again!
As it happens I'll be there again to do more work (including replacing the customer's computer, and connecting up to a newer email application) so I'm sure I can (and will need to) double-check the setup when I do that.
Fixes: 575
The outgoing server (relay.plus.net) was always meant to go via the Greenby proxy and thus, for migrated accounts, route to the Greenby server and therefore use the credentials as they exist on the Greenby account.
For technical reasons, a temporary situation exists where relay.plus.net is still routed directly to the plusnet server and so will still use the Plusnet account creds. Initially, following migration, the credentials are the same at both Greenby and Plusnet, its only if the creds are subsequently changed at Greenby that the problem arises.
Fixes: 377
Just FYI, @MisterW , when I got moved to Greenby, I changed nothing on my email client (I don't use webmail) and everything just carried on working as it had done previously.
Fixes: 575
@jab1 and that's exactly how its designed to work!.
The only 'not as designed' situation at the moment is the temporary routing of relay.plus.net direct to the 'avasout' servers.
njay
@jab1
Indeed, as nothing should need to be changed.
Theres is an exception though. If the email migrated is associated with a plusnet broadband account and that broadband account is closed (EE migrations spring to mind) then outgoing email via plusnet relay stops working.
Would be great if check could be put in place prior to broadband account being closed that if email has been migrated to greenby dont remove account in access list on plusnet relay server. Or convert plusnet account to email only like those that left ages ago and got to keep their email address?
Fixes: 377
Interesting, @njay , although I have not followed all the permutations of problems. I left PN May 2021, just before they decided to abandon 'mail-only' accounts for departing subscribers, so retained my account.
However, as one of my reasons for leaving was my suspicion (subsequently proved correct) was to downgrade the PN brand, I had it in my 'to do' list to move everything away from the BT group. For various reasons, the email aspect kept getting put on the back burner, only being reconsidered and actioned following my 'migration'. I have paid for a years retention at Greenby, but only to catch any stragglers I may have not advised of my move - come renewal time, the account will be closed.
kayeb
Your post here was extremely helpful to me thank you.
My husband’s email account, migrated from PN to Greenby about 6 months ago & stopped working about a week ago for no apparent reason.
The AI bot said he needed to change his email password. We did that. Then his sent emails wouldn’t work on the iPad, phone & laptop. The bot was telling us to reboot the iPhone, delete the email ptogramme & reinstall, change all the settings. I knew they didn’t seem logical or correct so I stumbled across your post.
Your fix of keeping the outward email password the same as the old PN account one did thd trick. Thank you for your tip.
However I think the service from Greenby is pretty awful, and the pair of them have come up with a pretty awful migration programme with lots of flaws. How on earth someone who isn’t that IT literate is supposed to navigate these glitches is beyond me. That’s 3 hours of my life I’ll never see again!
kayeb
I should add that we now realised the reason my husband’s emails had stopped working was that his Greenby email account had been suspended. All that would have been needed was to click on a button in the GB account area to reactivate the account. Goodness knows why the account had been suspended, there’s no obvious explanation. An AI bot just isn’t sufficient. Really annoying.
Sam8
Hi kayeb,
And yes, I am one of those who is not IT literate.
I use computer software and have won a number of awards for my publications - but I haven't a clue how the computer works.
I use emails - and very proficient at using emails too - but how email technology works I haven't a clue - I left that to Plusnet and my emails worked seemlessly for many years while with Plusnet.
By the by, I drive a car, safely and quite proficiently too - but I haven't a clue how the car works.
I am, therefore, a user - not a technician or engineer.
With emails, I send weekly group emails to ten recipients at my sports club and have done so for many years when at Plusnet, but now at Greenby they don't get through; well may be one or two of the group gets through - but it's a nightmare every week trying ti keep tabs of who has received them, or not. Greenby support said: " sorry, we have a problem with DKIM, (whatever that is),and will sort it with BT's help - been going on since migration December 2025 - now five months..
Greenby simply do not have a clue: 1. how to run their company and 2. how to understand the technology of sending and receiving emails.
Which leaves me to say, SADLY, who in their right mind would want to have a contract with Plusnet, let alone Greenby. Plusnet sold us out - all their one and half million email users. If only Plusnet had introduced a paid-for email service I am sure we would have all stayed with them. They were brilliant and it was like family...
computersupport
Further update.
With a different customer, who had recently switched to EE.
Her PlusNet account has likely been closed, so the relay.plus.net option was not available. I did try the mail.plusnet.enmail.co address for outgoing, which it connected to successfully after I accepted the certificate (it gives a certificate error - as the certificate this address gives is in fact the relay.plus.net certificate).
It looked like it would send via this server. However, it went into spam at one address (an Ionos-hosted address) and was outright rejected/bounced when attempting to send to both gmail and iCloud/Apple mail. I'm guessing down to the server it sends from not being configured as having permission to send emails from a PlusNet address.
In this user's case, they're going to switch to using gmail to send their email and transition away from PlusNet.
Fixes: 575
Close, but not quite!. The domain SPF record does cover the Greenby server, however the Greenby server doesn't yet have DKIM implemented. GMail, Microsoft & Apple insist on both SPF & DKIM and will either reject or mark as spam if they're not present.
Sam8
You are correct MisterW - as 90% of my 'group' email recipients are bounced back as suspected spam. All these group emails worked perfectly when with Plusnet - but not so with Greenby. Even when I send individual emails, many come back as suspected spam - particularly to gmail.com addresses.
And, here's my most recent message from Greenby when I raised this issue regarding group emails: "we are actively working with BT to fully implement DKIM as DKIM is not yet fully in place".
How could Plusnet palm us all over to a company that can't run an email service? It should never have happened the way it did. Plusnet should have ensured that such a company had all these protocals, criteria and intricacies in place at the start, as all Greenby is doing is trying to catch up on a subject that they have little or no knowledge of....
rogermhunt
I had exactly the same some weeks ago in that emails to .gmail did not send. I raised a Ticket and was told that it's not just a gmail related issue and that they were working with BT and others to fix the issue. About one week later I was told it was fixed and in fact it did work for me and has done since, until today ! Just had one bounce back from gmail saying 'suspected spam' etc.
