Greenby down again?
penfold
Fixes: 5
Re: Greenby down again?
That's what I'm going to be doing....
Who do you use?Huh
Fixes: 387
@penfold - Mythic Beasts.
Davidspeers
Working now.
stuck
Seasoned Pro
Fixes: 4
@penfold wrote:
Who do you use?Huh
I also use Mythic Beasts.
I picked them because of the many recommendations for them on this forum.  I've not been disappointed.
PhilipHeyes
Seasoned Champion
Fixes: 23
From Greenby at 04:55 AM Wednesday :
Apologies for the inconvenience you’ve experienced with your mailboxes not displaying in the portal. Please check your Greenby dashboard again now and confirm whether your mailboxes are showing correctly. If you are still experiencing any issues, please let me know and I’ll be happy to provide further assistance.
David60
Dear Phillip,
All seems to be working now - thank you
Only issue I have, after yesterday's outage, is that I cannot sent PNet emails from my Android phone using the G-Mail app. Don't use it a great deal but it has been working fine. Receiving PN emails through this G-Mail app is working with no issues.
Says something about a security certificate not being in date and therefore it causes a block on sending.
Happened once before and Plus Net updated the certificate - then all was well
Can you help please?
David
PhilipHeyes
Seasoned Champion
Fixes: 23
From a quick look using https://www.checktls.com/TestReceiver
Plusnet hosted SMTP : relay.plus.net   has problems starting a secure connection.
Can your Android phone send via Greenby hosted SMTP server : relay.force9.net    (use the same settings and credentials)
David60
Thank you for your reply.
I have entered the force 9 details but received the following message that is stopping me entering the new details as "Done" - "Certificate not valid - the Gmail app can't guarantee the security of this email address. Your messages would be at risk"
PhilipHeyes
Seasoned Champion
Fixes: 23
I can send via relay.force9.net using SSL/TLS via Port 465 and Certificate check
using MS Outlook on the PC & via Blue Mail on Android.
I am collecting <account>.plus.com emails via mail.plus.net again with SSL/TLS & Certificate check
and that is working for our Greenby hosted accounts.
David60
Thank you
I'll keep a watch to see the outcome
If I understand correctly you are looking at the issue and for the moment - I need take no action with my phone?
PhilipHeyes
Seasoned Champion
Fixes: 23
The earlier secure connection issues seen with relay.plus.net looks to be resolved now.
David60
Just tried to send a PN email from the phone and it is being queued as before?
Bookworms
I'm thankful I managed to resolve my seemingly intractable password problem with Greenby just before this outage began. I would probably still be tearing out what's left of my hair if I had been testing my configuration during a prolonged outage.
PhilipHeyes
Seasoned Champion
Fixes: 23
Was that the problem of changing a password in Greanby only to discover
relay.plus.net needs a matching password change using  the Plusnet portal ?
Bookworms
Yes. Rather than changing the passwords in account/settings I first had to delete them in Thunderbird/ [general] settings. It's the little gear icon at the bottom left of the accounts settings page and is easy to overlook.
