Failed to send Fetch Comand
stathe
Unable to see webmail as it says this is it Plusnet or my ignorance
5 REPLIES 5
Fixes: 1,495
Re: Failed to send Fetch Comand
Moderators Note
This topic has been moved from Broadband to Email
stathe
Does not help as link doesnt work and no ,explanation
corringham
Seasoned Champion
Fixes: 23
This is likely a Roundcube (webmail) problem, where the server times out while sorting the mail list.
The previously recommended solution has been to disable sorting of the mail list - that avoids the sorting taking longer than  the timeout period.
If that fails you could use another mail program to access your mailbox.
stathe
How do I disable sorting the  list
corringham
Seasoned Champion
Fixes: 23
I use Roundcube, but not Plusnet's version. On mine there is a "list options" icon at the left hand side of the "Subject" title bar.
That has a set of different options, including a "sorting column" radio button list - just select "none" in that list.
I do use sorting without problems, but my server works 🙂
