FURIOUS over email issues
SneakyPete
Continuing my battle to send emails - I am now on my second Android phone and refuse to have to resort to 'hacking' into developer tools in order to fix an issue that in my opinion is entirely down to Plusnet.
I have had my email and web site for 25+ years, firstly with Freenetname and through all the takeovers and merges up to where we are today with no problems at all with my email.
I have gone through all the 'fixes' and curl whatevers with no changes to my ability to receive emails.
Receiving is no issue, either by plusnet settings or even resorting to original freenetname settings!
What EXACTLY do I need in order to send an email??!!
4 REPLIES 4
Fixes: 251
Re: FURIOUS over email issues
Would be helpful if you shared the EXACT error message and the results of the diagnostic test.  There’s a multitude of reasons why you cannot send and they are not all to do with the email server.
it also helps to know how are you connecting…
  • Device
  • Email client
  • on / off Plusnet’s network
  • vpn
  • Default or secondary mailbox
  • How logging on (email address or account name)
  • Is this a new mailbox
  • what have you changed since it worked last
  • when did it work last (without changes)
SneakyPete
Hello again @Townman this is a continuation of an earlier post - I'm not overly tech savvy at 65½ years old but up until now I could at least work my way around an android phone.
__________________
Delivery to the following recipients failed permanently:
   * [email protected]
Reason: A message that you sent to the following recipient could not be delivered due to a permanent error. ** The remote server ?? responded with: ** [email protected] ??:?? This message was created automatically by mail delivery software on the server .
_______________
This is same return from any email address
Fixes: 251
Hi Pete,
I really helps to keep issues on a single thread ... I note that the mods locked the one you started previously - https://community.plus.net/t5/Email/Freenetname-email-still-not-sending/m-p/2008896#M49821
That and your initial description here, somewhat suggested that you cannot send to any address at all.  FWIW I'm older than you, so age is not really a barrier to understanding this space! Cheesy
If you can send to ANYWHERE at all, then you probably do not have an issue with the Android client, the email server configuration settings, username or password.  The issue is specific to sending to that address ... which potentially points to an issue with the addressee's email service.
Answering the above questions would still be helpful, especially, are you sending from [email protected] or from [email protected] ?  If the latter, do you also get issues sending to @gmail.com users?
For the sending domain @freenetname.co.uk SPF is implemented, so the usual (quasi valid) grounds for rejecting inbound emails DOES NOT APPLY.
I'd be asking the receiving party why they are rejecting the email ... their mailbox might be full, it might have been removed, that error message is very unspecific.
Fixes: 251
Hi Pete,
There is a raft of issues arising with sending to Microsoft hosted email services.  Can you please share the school's domain name (the bit after @).
