Emails not being delivered to gmail addresses
mooremj
Anyone else using Plusnet email not able to send to gmail addresses? Every time I send I get a non-delivery report.
9 REPLIES 9
smeech
Re: Emails not being delivered to gmail addresses
Yes. I'm getting a lot headed like this:
This is the mail system at host gateway1.enmail.co.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
                   The mail system
<xxx.xxxxxxxxxxxx@gmail.com>: host
    alt1.gmail-smtp-in.l.google.com[142.250.102.27] said: 550-5.7.1
    [213.5.177.100      12] Gmail has detected that this message is likely
    550-5.7.1 unsolicited mail. To reduce the amount of spam sent to Gmail,
    this 550-5.7.1 message has been blocked. For more information, go to 550
    5.7.1  https://support.google.com/mail/?p=UnsolicitedMessageError
    a640c23a62f3a-b9d6dfd8b61si305520666b.105 - gsmtp (in reply to end of DATA
    command)
rogermhunt
Yes. I've been in touch with Greenby yesterday and here's the response I got . . .
"I'm sorry to see you're having trouble sending emails to that Gmail address. Looking at the error message you've provided, it appears that Gmail's filters are flagging the messages as unsolicited.
We're aware of issues with delivery, either emails going into spam, or delivery issues to Gmail, iCloud, and other providers relating to DKIM (a type of email authentication).
We are working with BT to resolve this as quickly as possible. We are aiming to have this solved within a week, but we cannot be more accurate than this currently".
It's a ridiculous situation as far as I'm concerned. I don't know whether any other email providers are having the same issue or whether it's just Greenby.
pvmb
Seasoned Pro
Fixes: 11
Yes. It's well known and there are whole forum threads dedicated to it.
mooremj
It really is. Extremely frustrating.
mooremj
That's odd. Until I started this thread, the latest discussion thread in the Email forum was posted last year.
pvmb
Seasoned Pro
Fixes: 11
@mooremj
You CANNOT be serious! 🤣
Fixes: 353
It is not just PN  having these issues with Gmail (and Microsoft). Basically, these two behemoths are intentionally making life difficult for many other mail providers, I suspect, but can't prove, obviously, so they can eliminate the opposition and then harvest data when they have 'persuaded' you to use them in preference.
I note that we had a similar issue a while back, which got 'resolved', only for the refusal reason to change.
mooremj
abitpedantic
@mooremj
Try this for light reading https://community.plus.net/t5/Email/Problems-sending-to-gmail/td-p/2041690
It seems that Greenby's standard reply is that they hope to have it sorted in a week but there is no sign of a solution.
I've PM'd @Chris_S a couple of times since then but he had no news.
