Email settings
peebee
Email settings
After a prolonged "discussion" with the Complaints Dept. at Plusnet the following settings have been advised:
2. Edit the SMTP Server Settings
Find and select relay.plus.net from the list of SMTP servers and click Edit.
Ensure the Server Name is relay.plus.net.
Set the Port to 25.
Set Connection Security to None.
3. Configure Authentication
If you’re using a Plusnet internet connection:
Set Authentication method to No authentication.
Click OK to close the window.
The suggested SMTP Server settings and Authentication settings are VERY DIFFERENT to what has worked in the past where security and authentication were enabled!
There must have been a big change to the server which meant that secure connections no longer worked and that all security and authentication had to be removed. Why wasn't such a big change communicated properly?
25 REPLIES 25
PhilipHeyes
Seasoned Champion
Fixes: 26
Re: Update on Plusnet Email Migration
SMTP Port 25 and No credentials will not work the moment your laptop or mobile leaves the Plusnet broadband network.
In fact Port 25 with Credentials is blocked by many ISPs ( e.g. Orange ) to avoid spam issues.
I am using SMTP Port 465 this ensure encryption and credentials are used, important for security on public hotspots.
Fixes: 388
@peebee I don't know who you spoke to in 'Complaints', but (2) is totally wrong - port 25 should never be used for SMTP submission.
Be aware that first-line support/phone agents have no knowledge/training in the email area these days, so unless they have been employed for a very long time, what they say should be taken with a large bag of salt.
Also, authentication is more important when you are not using a PN connection, although setting it is a good idea anyway.
Fixes: 251
I have escalated the advice given requesting a review.
The correct details are
  • Server relay.plus.net
  • Port 587
  • Encryption STARTLS
  • Authentication - same as incoming
The only semi-legitimate reason for using the deprecated (outdated) port 465 is where the email client is deficient in that it does not support STARTTLS as the encryption standard.
peebee
  • Port 587
That is what I had prior to the Complaints Dept. advice........ and it wasn't working with Thunderbird - timeout error message was all I got when sending.
My email client is on a desktop connected to Plusnet so I never uses other networks.
peebee
[CSA Removed] - Complaints Advisor
My name is Lidia, and I work in the Executive complaints team in Plusnet Sheffield, and I have now taken full ownership of your complaint to ensure we progress to a satisfactory resolution.
Moderator's note by Adie (Dvorak) CSA name removed as per Forum rules
Fixes: 251
If you are getting timeouts, then you are connected and fiddling with these settings will not change that.  What might help is changing the server timeout settings.  Sending a large email can time out - I set mine to 2 minutes on outlook.
Also line faults can give rise to SMTP server timeouts.  What broadband connection are you using?
peebee
With "your" settings - timeout message
With the Complaints Dept. settings - no timeout message and email is sent correctly.
Very small test email in both cases. Don't think it is server timeout settings issue.
Not a line fault. I'm on FTTC to the house and wifi within the house.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
PhilipHeyes
Seasoned Champion
Fixes: 26
We don't know what platform(s) or what email application(s) are being used.
Has something changed / updated on your laptop or mobile shortly before the failure to send via SMTP with encryption ?
E.g. has a change been made to the enabled SSL or TLS versions on a Windows PC ?
Does the SMTP timeout issue affect both your computer and your mobile ?
Are you using a very old version of an email Client ?
Routefinder
Sorry if I have missed anything but PN are explicit with their (updated?) details say this (on this page https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/ )
You'll need to give a few more details when you're setting up your email application. They can be pretty confusing, so here's what to use.
  IMAP POP
Incoming server imap.plus.net mail.plus.net
Incoming port 993 995
Outgoing server relay.plus.net relay.plus.net
Outgoing port 587 (recommended) or 25 587 (recommended) or 25
STARTTLS Yes Yes
SMTP Authentication (only needed if you're sending emails from a non-Plusnet Internet connection)* Yes Yes
* This is only available if you've got an active Plusnet broadband account
If your client doesn't support STARTTLS, then you can set SSL/TLS to Yes and set the outgoing port to 465.
If you've been with us a while, your domain might be '.force9.co.uk or '.free-online.net'. If so, change '.plus.net' to '.force9.net' or '.free-online.net' for both your incoming and outgoing servers.
Fixes: 251
That information is wrong and has been for years.  Being correct and what might work are not the same thing.
STARTTLS does NOT fit under IMAP or POP3 - the instructions are therefore confusing.
The approved port allocation for SMTP is only 587 - see RFC 8314 RFC 8314: Cleartext Considered Obsolete: Use of Transport Layer Security (TLS) for Email Submission ... - specifically see...
7.3.  Submissions Port Registration
   IANA has assigned an alternate usage of TCP port 465 in addition to
   the current assignment...
Historically, port 465 was briefly registered as the "smtps" port.
   This registration made no sense, as the SMTP transport MX
   infrastructure has no way to specify a port, so port 25 is always
   used.  As a result, the registration was revoked and was subsequently
   reassigned to a different service.
The use of port 25 and 465 are NOT compliant with the RFC for email message submission.
Whilst the instructions reference the secure ports for IMAP and POP3, the correct encryption is not specified - TLS/SSL for those servers.
The suggested timeout on port 587 but not 25 is a matter which requires investigation.  @plusnettony - is there any intel to support the claim that port 587 gives rise to SMTP time outs, but port 25 does not?
PhilipHeyes
Seasoned Champion
Fixes: 26
I have just done a quick test in MS Outlook and we have no issues sending Authenticated and Encrypted via relay.plus.net using STARTTLS via 587 or using SSL/TLS via 465.   Both methods work and both accept the test email in < 10 seconds.
Fixes: 251
@PhilipHeyes
What might work is not the same as being compliant with the standards.  Being compliant with the standards will always work with standards compliant implementations.  Using configurations which are not compliant with the standards run the risk of no longer working should components change or be upgraded.
I suggest that at this time, strict compliance with the standards is highly desirable, if not indeed essential.
Routefinder
Thanks for the insights but it seems that compliance vs 'what works' is not uncommon???
I have another email address with Namsco and they use Team Blue as their provider.
The advise they give for POP3 is
**Incoming Server Information**
- Port - 995 with SSL ON
**Outgoing Server Information**
- Port - 465 with SSL ON
It gives me pause to wonder how many email providers (what do Greenby recommend?) use the compliant vs the (older?) what works?
PhilipHeyes
Seasoned Champion
Fixes: 26
STARTTLS is a vulnerable security protocol that leaves us not knowing if encryption is working.
