E mail will not send when away from home router
brookorchard
Long standing problem that I phone 7 will not send e mails when away. All normal settings checked and historic posts looked at. The message is that recipients e mail address rejected by server. Any further ideas please?
12 REPLIES 12
Fixes: 579
Re: E mail will not send when away from home router
Do you have 'Use Authentication' set for the outgoing server ( relay.plus.net ) ?
brookorchard
Thanks for your very fast reply.
When we go to authentication it offers 4 options, MD5, Challenge-Response, MD5 Digest, HTTP MD5 Digest, NTLM or Password. Which should we use as when we 'tick' password it doesn't seem to be saved as the option? Thanks.
Fixes: 579
That doesnt sound right. I'm not familiar with Apple Mail ( I assume that's what you are using on the iPhone ) but there's a guide here https://support.apple.com/en-gb/HT201320
brookorchard
Hi and thanks again. It is an Apple mail account host but a plus net mail account. The Apple  guide doesnt' really help unfortunately hence coming back to the community.
Fixes: 579
I'm not quite sure I understand what you're saying there.
If you are uising Apple mail to access your plsunet mail account, then using the guide, you add a new mail account but use the details for your plusnet account. The Plusnet settings are here https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/ in the  'What other settings do I need' section
Fixes: 245
With iPhone setup. you can / need to specify the username and password on the SMTP server settings.  I am somewhat surprised that you were able to configure the email account without them.
adam945
Fixes: 113
Hello @brookorchard, thanks a lot for getting in touch. I know it sounds like a simple question but, have you enabled mobile data for Apple Mail?
 Adam
 Plusnet Help Team - Leeds
Fixes: 245
@adam945
Good call!!
brookorchard
Yes, mobile data has always been on. I'm not quite that bd a technophobe. In any event, problem now resolved.
brookorchard
Thanks but the account has been set up for years with the Plusnet settings. The issue has now been resolved.
brookorchard
Thanks. The account has worked perfectly (other than with the problem I have identified) without the username and password but having now added these the problem has been resolved so many thanks.
Fixes: 245
When you connect to the outbound server from "off" the Plusnet network - as in 3/4/5G mobile network - you MUST use the username and password on the SMTP server.  When on the network - as in connected over wifi to your home router - you do not need then credentials.
For the very issues you have encountered, it is wiser (certainly simpler) to always specify them.
