Changing my Password on an old Force9 Mailbox
OldTimer17
I want to change my password on an old Force9 mailbox that I still use but when I log into my portal and go to Manage Accounts I dont see an option to change the mailbox password (I dont even see the mailboxes listed just an option to change email address and portal password).
At the top in yellow it does say -
Change already in progress
You are not currently allowed to make a change. There is already a change in progress. Please try again later
which I have no idea what this is (I did change the password to reacess my portal but carnt see it being that).
6 REPLIES 6
Fixes: 146
Re: Changing my Password on an old Force9 Mailbox
@OldTimer17  welcome to the community
Try this link https://www.plus.net/manage_my_mail hopefully it will bypass the other message.
You may need to be logged in for the link to work.
HTH
OldTimer17
Thanks. That does take me to the Manage Email page but the only email address listed is different to the one I'm using (uses an extra initial in my name) and it doesnt give an edit option (see encloded screenshot). Likewise on the Mailboxes tab it just lists the (slightly different) email address and just gives a rename option but no option to manage/change password etc.
Fixes: 244
If you only have ONE email box, you change its password by changing the ACCOUNT password.
Look at the CATCH ALL tab - if that shows catch all enabled then [email protected] will go to that mailbox, so you might not see a mailbox for the address you use.
OldTimer17
No the Catch All status is off.
The email account I use to log into webmail is "username+firstname" so this looks like I have set up an additional mailbox. My email address is [email protected].
Fixes: 1,662
If there’s only one email address in the mailbox tab, could it be set up as an alias of the default mailbox?
OldTimer17
I’ve changed the force 9 account password in the User Portal but the email account is still accepting the original password.
