Cant send e mails.
Alan1955
Cant send e mails.
E mail has been fine using outlook but few days ago stopped sending, receives OK.   error message ....554 avasout-ptp-002 smtp ESMTP server not available (blacklisted by local policy) - cant send email.
Looks like something blocked at Plusnet end.  Get the same on my laptop as PC but Ipad seems to be OK.
10 REPLIES 10
Fixes: 387
Re: Cant send e mails.
@Alan1955 Who is your email with - is it <someone>@something.plus.com> or something else? Is it the same address on all three devices?
Alan1955
e mail address is @**@********.plus.com. same address on all three
Fixes: 387
@Alan1955 I would edit that post by 'starring-out' the name and domain., but thanks for confirming.
Fixes: 387
It is strange that the iPad seems to be OK - to be honest I would have expected that to be the problem device.
Unfortunately, this is slightly out of my 'comfort zone' but I know there are a a couple of people on here who know more than me - if they don't pick this up, I'll give them a nudge.
Alan1955
John,
many thanks.  It looks like others have had the same problem and not just Plusnet. I did try phoning Plusnet but got nowhere even though it looks like it needs Plusnet to unblock something.
Alan
Fixes: 387
@Alan1955 You may be right i but I will ask @Townman for his expert guidance on this.
Alan1955
Thank you.
Found reference to this problem and the suggested fix was to turn off the router for 90 mins so that it would select another (non blocked) IP address. switched it off for 15 mins and now I can send e mails again.  It did not clear those in my out box, I had to start again with those.  Not sure if this is a permanent fix or it will happen again so still up for some advice as this is all a bit beyond me,
Alan
duncanio
I have been receiving the same message today:
"Server error: '554 avasout-peh-003 smtp ESMTP server not available (blacklisted by local policy)'"
and cannot send emails (but receiving ok).
Did the error message return? I switched my router off for 30 minutes but to no avail.
Can anyone help?
RPMozley
Seasoned Pro
Fixes: 18
Do you have a Metronet email account or Free-Online email account?
If yes see this thread https://community.plus.net/t5/Email/Email-settings-issue-just-started-today/td-p/2005097/jump-to/fir...
That's RPM to you!!
duncanio
I have a free-online account so 'Yes'. Thanks for your response.
