Cannot Send Email when Tethering through Huawei P10 Mobile Phone
G4BUE
Can somebody suggest why I cannot send emails from my desktop computer when connected to the internet by tethering through my Huawei P10 mobile phone, please?
I use the email program Pegasus on my desktop Windows 10 computer for sending and receiving email.  It is Pop3 and I use the <mail.plus.net> setting for receiving emails and the <relay.plus.net> setting for sending emails, and this has been working for many years without any problems when I connect direct to the internet through my Plusnet account.
I have recently been having broadband connection problems and have used the tethering option on my Huawei P10 mobile phone to enable my desktop computer to connect to the internet.  When I do this, I can still download my emails, but cannot send them.  The program returns the following:
07:35:30.032: --- 14 Sep 2021, 7:35:30.032 ---
07:35:30.032: Connect to 'relay.plus.net', timeout 30 seconds.
07:35:31.535: >> 220 avasout06 smtp relay.plus.net
07:35:31.536: << EHLO [192.168.43.134]
07:35:31.567: >> 250-avasout06 hello [213.205.194.3], pleased to meet you
07:35:31.567: >> 250-HELP
Can someone tell me what this means, please, and if there is a different setting I have to use when sending emails whilst connected to the internet through my mobile phone?
Thanks for any help and / or advice.
7 REPLIES 7
Fixes: 1,495
Re: Cannot Send Email when Tethering through Huawei P10 Mobile Phone
Moderators Note
This topic has been released from the spam filter.
G4BUE
Thank you, but why was my post treated as spam, please?
G4BUE
I have just realised that although my original post is saying the problem has been fixed, it has not!  The fix only applies to the post being treated as spam, I still don't have the answer(s) to my original post question(s).
Thanks again for any help and / or advice.
Fixes: 585
@G4BUE  when not using your Plusnet connection, you will need to specify authentication on the outgoing (smtp) server. Use the same username/password that you use on the incoming server. Authentication will work with both PlsuNet and non-plusnet connections so you can leave it configured.
G4BUE
Many thanks for your help, MisterW, but I don't understand how to "specify authentication on the outgoing (smtp) server",  Can you explain how to do that, please?
G4BUE
As you were MisterW.  I have just worked out how to configure it in my Pegasus email program, and I am now able to send emails while tethering to the internet through my mobile phone.
A big thank you for your help.
Fixes: 1,495
Moderators Note
This topic has been moved from Mobile to eMail
