Autofill webmail login
Speckledhen49
When I login to my free-online webmail I have to enter my username and password. Up until recently this was filled in automatically but now has to be done manually. Finding it a pain and have tried various ways to sort it but no joy. Any help would be much appreciated TIA
6 REPLIES 6
Fixes: 240
Re: Autofill webmail login
Auto fill is solely the function of your browser, not the service being accessed.
James30
Fixes: 32
@Speckledhen49 - As Townman says, autofill is done by the browser by recognising that it's a username and password box and giving you auto-fill options, not part of the website. I would try another device/browser and reset the browser to factory settings ( wiping all plugins, history, cache, cookies etc). That should fix it.
James - Plusnet Sheffield
Speckledhen49
Thanks for your suggestion. Seem a bit drastic to lose all my other info. The strange thing is auto fill works on all other sites but not plusnet on this laptop although it does on my desktop PC. Looks like it is something I am going to have to live with
Fixes: 240
Check the device’s security settings for the site.
Speckledhen49
How do I do that please
Fixes: 240
All depends on the browser you are using and the device. Look for settings / passwords under HELP in your browser.
If it’s on an iPhone or the like, such is probably in the device settings.
