Accessing spam folder
Surfer
I am having a legitimate Gmail & pobox.com email being blocked and I need to access the spam folder on my account to view it.  Where do I access this folder and to get messages released?  Thanks.
6 REPLIES 6
Fixes: 480
Re: Accessing spam folder
Moderator's Note
This topic has been moved from My Account/Billing to Email
Fixes: 585
@Surfer  what happens to Spam email and where it goes , depends on your Spam settings. Login to your account , goto https://www.plus.net/manage_my_mail and click the Spam tab to check your settings
Surfer
Sorry Baldrick1 I have no idea what the "thumb" is.  All I need to do is to view the spam messages, mark sender as being "safe" and have the emails released.  Thanks.
Fixes: 480
@Surfer
If you can't find it after following @MisterW's instructions then note that by default emails with a high Spam score are automatically discarded:
Surfer
MisterW I have followed your advice and have tried to update the Spam settings as the the options which to me are as clear as mud, but hopefully I have selected the correct option and will now be able to view spam messages. The aggressiveness of the spam filter was set to maximum and have now changed it to medium.
The emails come from a forum which I have been a member of for over 12 years so not sure why the filter has decided that everything from there is spam including Gmail.  Case now of wait and see.
Fixes: 585
@Surfer I'd certainly suggest setting the 'Discard Obvious Spam' to Off.  Then check the 'Add SPAM to the subject line'. You can then choose whether Spam goes to a separate SPAM folder or to Inbox. I personally have the aggressiveness set to minimum.
