Writing / editing posts on phone messes with HTML special characters
Fixes: 246
I have noticed that posts written / edited on my iPhone using ampersands can result in the HTML code for ampersands appearing as text.
I'm not completely clear exactly what happens so I'll post illustrations below.
4 REPLIES 4
Fixes: 246
Re: Writing / editing posts on phone messes with HTML special characters
This post is typed but will not be edited...
Ampersand A&B
Less than 1<2
Greater than 3>1
Fixes: 246
This post was a copied and pasted then I edited after it was posted...
Ampersand A&amp;B
Less than 1&lt;2
Greater than 3&gt;1
On opening this for editing the special characters display as their HTLM codes.
Fixes: 246
...and when the edited version is posted, the HTML codes are not post edit processed to return them to their character variants, yet if I put the right characters here as text to tag Jack @jaread83 something in the back ground foes done smart magic ... though I know if I edit this post that magic disappears in a puff of smoke.
Lithium really ought to be doing much better here - especially given their "industry leader" reputation!
Fixes: 246
Dam!
... in the back ground goes and does ...
