What happened earlier.....?
DS
Seasoned Champion
Fixes: 22
Re: What happened earlier.....?
And thanks JayG for the notification tip (never thought to look down there) Also, I left spaces in the reply above (and this one), but it's removing them (so a wall of text instead)
Fixes: 374
@jab1 wrote:
@DS - yep, it's broken again, no HTML, no formatting, and clicking my avatar only brings up my profile, not the usual options. GRRRR!!
Fingers (and toes) crossed Smiley - looks like it's sorted!
JonoH
Fixes: 157
This has indeed been fixed by clearing the cache, some users may need to clear theirs if they're experiencing issues. In the meantime, our suppliers are looking into how we can stop this reoccurring. Thanks for your patience.
 Jono H
 Plusnet Community Manager
Fixes: 374
So they don't know what they've got wrong then, @JonoH ?Smiley
DS
Seasoned Champion
Fixes: 22
I'm not so sure it is back to normal.....
I could be wrong, but don't recall seeing a rather long and detailed URL when hovering over the thumbs up button...?
But from what else I have looked at, is does appear to be working as intended.
JonoH
Fixes: 157
Strange, I don't see that. Have you cleared your cache? Is anyone else seeing this?
 Jono H
DS
Seasoned Champion
Fixes: 22
(only quoting to check this works, don't shoot me down mods!!)
Hmm, well I've just done this
Twice btw
And hovering over the thumbs up for your reply shows all of this
https://community.plus.net/t5/forums/v4/forumtopicpage.kudosbuttonv2.kudoentity:kudoentity/kudosable...
Not sure if any of that is unique to me, as in the ticket= bit, but nope still seeing this
(using Firefox is this help @JonoH)
edit to test. Here's the link without the http at the beginning
community.plus.net/t5/forums/v4/forumtopicpage.kudosbuttonv2.kudoentity:kudoentity/kudosable-gid/1634531?t:ac=board-id/Community/message-id/15532&t:cp=kudos/contributions/tapletcontributionspage&ticket=M3WMO_uxKKVe_43253
HTH
Fixes: 374
@JonoH I see it too, no I haven't cleared my cache.
JonoH
Fixes: 157
Thanks guys, I'll raise it again, could one of you share a screenshot, please?
 Jono H
MauriceC
Resting Legend
Fixes: 17
I also see that URL in the bottom line of the screen.
DS
Seasoned Champion
Fixes: 22
(just testing the quote button to the right of the reply window too (I honestly don't recall seeing it there and have always typed it out myself - I've actually just verified this using an old screenshot and nope it wasn't there for me. Not an issue though as I use NoScript:))
As above, clearing didn't 'fix' it for me
Anyway, I'm sure there were 6 scripts running on these forums, now there's only fiveHuh
The five running ones are:
plus.net
cloudflare.com
googletagmanager.com
jquery.com
omtrdc.net
MauriceC
Resting Legend
Fixes: 17
Here ya go.  Code Inspector centred on the thumb button for added info on source.  Button works as expected.pnet-bug.jpg
DS
Seasoned Champion
Fixes: 22
It might be a bit big, but here ya go!!:)
Hover over the thumb and note the URL at the bottom;)
DS
Seasoned Champion
Fixes: 22
I've stumbled on something else, but it's related to my image above @JonoH
If you click on it (+), to make it the normal size, there's an odd date showing
Where's the 15 May 2007 coming from?
On returning to the site after my lunch I see that the Options menu is missing from the view:
https://community.plus.net/t5/forums/unreadpostspage/tab/message:full
The Next and Previous are missing due to my compression of the screen, just to take a smaller image.
