What happened earlier.....?
DS
Seasoned Champion
Fixes: 22
Re: What happened earlier.....?
The upload issue appears to be fine atm Smiley
Though sporadic issue still might need looking at Sad
One second it's this:
And then it's normal:
(happened a few times so far today)
DS
Seasoned Champion
Fixes: 22
I've never seen the following error message before Undecided
It started with the recent posts page greying out.
F5'd a few times until normal viewing was restored.
But:
(obviously using FF, so could be this at fault)
Fixes: 384
@DS  I've seen that 3 or 4 times - an F5 usually clears it.
DS
Seasoned Champion
Fixes: 22
Thanks for that @jab1
Thought I was going Crazy3
Fixes: 384
@DS  Nope, it's not you (or me) going Crazy3 - it's this bleep-bleep forum.Wink
DS
Seasoned Champion
Fixes: 22
I'm with you on that!! Wink
What with all the bugs in their billing systems etc etc etc etc etc, guess some escaped into here too!!Lips_are_sealed
Though in honesty, I'm only back on here, lurking, until my fibre connection is either sortedKnuppel or they allow me to escape....?
If it does get sorted, then a lot depends on whether the forums ever become bug freeUndecided as it gets frustrating Ticked_off
DS
Seasoned Champion
Fixes: 22
I see the bugs have escaped again.
go here - https://community.plus.net/ - scroll down and the users online has gone odd again (image already on here).
Hey ho.
Fixes: 384
Yup, @DS  - and the loading time for boards is creeping up again.Ticked_off
JonoH
Fixes: 157
All looks okay to me?
 Jono H
 Plusnet Community Manager
DS
Seasoned Champion
Fixes: 22
@jab1 At this present time, but only just came on, it's a little slow to load, but better than it can be...
@JonoH Last night it was as per the lower part of message #1. The users online were exactly as posted, though there was an additional bit at the very bottom. There was a pink 'view all' text showing at the bottom of a very long page. Once clicked on it was only showing one user as online - it's normally always there - LithiumSR. Their icon was fine and no others were showing. Ironically this user isn't showing today, but as I said, it's normally always there Huh
I use CCleaner too, so doubt it was any stray cookies at my end causing it.
But atm, it seems to be in order (apart from 2018 showing at the bottom, but that's mentioned elsewhere;))
DS
Seasoned Champion
Fixes: 22
Actually @JonoH , scrub the above!!
If you're looking at the users online and hit F5, you see this whilst the page reloads.
(didn't grab all of it, just a sample)
So yes @jab1 it does appear to be on the blink again.
DS
Seasoned Champion
Fixes: 22
Am I alone on thisHuh. I'm finding these forums very slow to load/respond for most of today. It's the same with the main plusnet siteHuh
No other site seems to be affected. If it helps diagnose, I'm still, for reasons unknown, being allocated the following DNS settings -
Primary DNS: 213.120.234.42
Secondary DNS: 213.120.234.38
Not the normal:
212.159.6.10
212.159.6.9
Anyone seeing the same sluggishness?
Fixes: 384
Not seeing any major sluggishness, @DS  - just a slight delay when opening individual boards.
DS
Seasoned Champion
Fixes: 22
Thanks @jab1. From your post, I hit reply and it took 15 seconds to fully load the reply 'window'
I had it earlier where a page could take around 30 seconds to load too.
I even tried to load a few in one go, they took ages to fully load.
Hmm, I don't think it's FF (60.0.2), though it has had 2 updates in the last 48 hours...
Just odd it only seems to be PN sites.
(unless PN's odd DNS is delaying it?)
edit. I type my reply, click Post and the page took 12ish+ seconds before it fully loaded my reply.
Fixes: 384
Right - to followup, @DS reply page loaded almost instantly, and individual topics open as quick as I would expect - it is just opening individual boards that seems to be slowing (again).
It isn't FF - I have the same issue on Safari & Dolphin on my iPad.
