What happened earlier.....?
MauriceC
Resting Legend
Fixes: 17
Re: What happened earlier.....?
I agree tonight most of the symptoms occurring on Friday are back!
Mav
Fixes: 518
Very odd as FF seems to be OK now for me.
Forum Moderator and Customer
Fixes: 382
Still only working for me on Dolphin.
NOT working on FF (on laptop or iPad), Safari on iPad, or Pale Moon on laptop.
I will wait and see what tomorrow brings, but tbh, I don't hold out much hope.Sad
Fixes: 382
The fairies have been at work overnight Grin - all back to normal this morning.
billnotben
It seems odd that other lithium boards remain relatively problem free.
Maybe the cause of this is elsewhere.
Perhaps it's not so easy to fob off commercial enterprises with "unresolved billing problems".
DS
Seasoned Champion
Fixes: 22
Not sure if this is a glitch already present in the forums, or related to recent events.
But I read the forums via the recent posts page.
Had a subscription email as the OP replied, refreshed the recent posts page and sure enough it WAS there.
I clicked on it, read it and went to reply. This is where 'it' happened (again - twice in the last 5 days), after clicking reply the message is no longer available - it's gone from any forum section.
So, @Mav or @dvorak is there a known issue whereby we can see a reply and then the spam filter 'hides' it?
The reply was directly after this one - https://community.plus.net/t5/My-Order/landline-phone-and-broadband-not-activated/m-p/1620395#M10541
It was posted 14:32 if this helps.
If you guys can't see it, have the issues of late returned?
TIA
Fixes: 1,495
In this case the spam filtering removed it.
Mav
Fixes: 518
Occasionally the Spam Filter picks up a post after it has been edited.
We usually release these as quickly as possible.
DS
Seasoned Champion
Fixes: 22
Thanks guys Smiley
Though I saw it, read it, went to reply (it wasn't edited by the OP afaik)
It then went to spam.... seems a bit bonkers to me to go after it was posted (and unedited)
It came back, then I replied and my reply went awol
Thus far, here's what happened the first time
And I then replied which I think posted, pressed F5 to check and right now that thread does this
Anyhoo, I'm not going to reply to that thread and will leave PN to deal with the OP Smiley
(none of your faults (Mike and Ade), I'm just pretty wound up with PN atm, though I'm trying to look at the positives, but can't seem to find any atm)
DS
Seasoned Champion
Fixes: 22
Firstly I hope this posts
Secondly, I was logged out and it's all gone very s-l-o-w again, more so the recent posts page, it's taking a long time to fully load
I did try other sites (google and youtube thus far) and they're loading perfectly fine.
Let's see if I'm alone on this?
Fixes: 382
@JonoH In the past 20 minutes, with no changes made by me, again I get my forum profile instead of the drop-down when clicking my avatar, and cannot collapse unwanted boards -wth is happening?
back to 'normal' @ 11.22Huh
JonoH
Fixes: 157
I'm not sure @jab1, we have an open incident with Khoros (Lithium have rebranded), they're unable to replicate it but are still investigating. They've asked me to get a video of it happening but try as we might we cannot replicate it internally.
 Jono H
 Plusnet Community Manager
Fixes: 382
Well, @JonoH  it's still happening here, but as I'm doing other things as well as being on here, I can't say exactly what happens, but I was certainly nowhere near the forums when they 'wobbled'Smiley
DS
Seasoned Champion
Fixes: 22
Probably a coincidence, but according to google, this was recent:
The coming together of Spredfast and Lithium as Khoros
Then a few days later I actually started this very thread......
This won't help jab1, but using FF and I'm not seeing the same issue this time Huh
(though if this makes a difference, I'm currently only allowing the plus.net and code,jquery.com scripts to run - I use NoScript)
edit. I was lurking around the time jab1 first mentioned this, but note at 11:22 it's normal now
DS
Seasoned Champion
Fixes: 22
As of 0100, it took me 3 attempts to sign in - F5 worked in the end
And uploading pictures does not work - upload works so far, but the pink done box does nothing at all Sad
(not even sure if this will post either .... here goes)
