Trouble with 212.159.8.110?
- Feedback
- Community Site Feedback
- Re: Trouble with 212.159.8.110?
02-11-2014 11:48 AM
Some of the traceroutes are going a bit weird, e.g.:
[tt]traceroute -q 1 -N 1 -T -p 80 212.159.8.110
traceroute to 212.159.8.110 (212.159.8.110), 30 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 79.503 ms
2 lo0.10.Central10.ptn-bng02.plus.net (195.166.130.190) 89.081 ms
3 irb.10.PTW-CR01.plus.net (84.93.249.1) 60.228 ms
4 te9-4.ptn-gw01.plus.net (195.166.129.33) 74.621 ms
5 gi5-1.peh-cr02.plus.net (84.93.232.61) 98.496 ms
6 po5.peh-cr01.plus.net (84.93.232.16) 96.565 ms
7 vlan2657.peh-elb01.plus.net (84.93.232.44) 53.121 ms
8 vlan2657.peh-elb01.plus.net (84.93.232.44) 85.209 ms
9 community.plus.net (212.159.8.110) 124.437 ms
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 vl2657.peh-cr01.plus.net (84.93.232.41) 108.576 ms
21 vlan2657.peh-elb01.plus.net (84.93.232.44) 98.331 ms
22 vlan2657.peh-elb01.plus.net (84.93.232.44) 85.526 ms
23 vl2657.peh-cr01.plus.net (84.93.232.41) 71.760 ms
24 vlan2657.peh-elb01.plus.net (84.93.232.44) 145.218 ms
25 vlan2657.peh-elb01.plus.net (84.93.232.44) 95.476 ms
26 vl2657.peh-cr01.plus.net (84.93.232.41) 91.824 ms
27 vlan2657.peh-elb01.plus.net (84.93.232.44) 68.795 ms
28 vlan2657.peh-elb01.plus.net (84.93.232.44) 51.918 ms
29 vlan2657.peh-elb01.plus.net (84.93.232.44) 90.513 ms
30 vlan2657.peh-elb01.plus.net (84.93.232.44) 64.040 ms
[/tt]
Perhaps some routing is messed up, or there are some routing changes that haven't fully propagated to all bits of network kit yet?
Edit: Whatever the problem was, it seems to have cleared now and it's working again.
13-11-2014 2:18 PM
Tracing route to community.plus.net [212.159.8.110]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 100 ms 71 ms 33 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 32 ms 33 ms 32 ms link-a-central10.pcl-gw01.plus.net [212.159.2.168]
4 33 ms 35 ms 32 ms xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5 51 ms 32 ms 32 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 33 ms 32 ms 33 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
7 53 ms 41 ms 43 ms gi5-1.peh-cr02.plus.net [84.93.232.61]
8 45 ms 42 ms 43 ms po5.peh-cr01.plus.net [84.93.232.16]
9 57 ms 44 ms 41 ms vlan2657.peh-elb01.plus.net [84.93.232.44]
10 42 ms 46 ms 43 ms community.plus.net [212.159.8.110]
Trace complete.
Tracing route to community.plus.net [212.159.9.110]
2 32 ms 32 ms 38 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 33 ms 32 ms 32 ms link-a-central10.pcl-gw01.plus.net [212.159.2.168]
4 32 ms 34 ms 32 ms xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5 33 ms 33 ms 32 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 39 ms 38 ms 39 ms gi5-8.ptp-cr01.plus.net [84.93.224.48]
7 40 ms 39 ms 39 ms vlan2657.ptp-elb01.plus.net [84.93.224.36]
8 39 ms 39 ms 39 ms community.plus.net [212.159.9.110]
Trace complete.
13-11-2014 5:39 PM
13-11-2014 8:25 PM
Whilst one may connect to either of the IP addresses on different occasions that one connects to the forum, which I've noted when I occasionally check, on re-reading your post today I was minded to check the traceroutes with the above results.
I further checked the consistency of those traceroutes with which ever IP I was actually connected to on the Forum. But because I was monitoring the Forum IP more closely I then observe that despite always having at least one tab open, the IP address had changed after either I posted or refreshed a tab, so I now need to monitor more closely to see exactly when it does change.
However before I do that, I'm going to set the IP address in Hosts to see if I get problems with one IP address and not the other.
14-11-2014 11:08 PM
Things are much more troublesome of 212.159.8.110 but still testing.
14-11-2014 11:15 PM
Quote from: Anotherone The problem is they should not be different which is why I would not call them "usual"
The gateways are in buildings in different parts of London and there's routing from each back to Sheffield with a link between the two London buildings - of course there's a high chance that the routing may be different!
Edit: Too add to that the targets are in different datacentres, one is in peh and one in ptp.
14-11-2014 11:25 PM
And actually I didn't mean why are they different in that sense, why the different number of hops?
14-11-2014 11:40 PM
Looking at the trace routes the first goes pcl -> ptw -> ptn -> peh.
The second goes pcl -> ptp so of course it has fewer hops.
I'm on a ptw gateway and you can see the routing for me goes the other way:
C:\Users\John>tracert 212.159.8.110
1 1 ms <1 ms <1 ms tg582 [192.168.1.254]
2 21 ms 20 ms 21 ms lo0-central10.ptw-ag02.plus.net [195.166.128.196]
3 21 ms 21 ms 21 ms link-a-central10.ptw-gw01.plus.net [212.159.2.148]
4 21 ms 20 ms 20 ms xe-0-2-0.ptw-cr01.plus.net [212.159.0.248]
5 28 ms 27 ms 22 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
6 39 ms 31 ms 30 ms gi5-1.peh-cr02.plus.net [84.93.232.61]
7 38 ms 33 ms 33 ms po5.peh-cr01.plus.net [84.93.232.16]
8 39 ms 29 ms 30 ms vlan2657.peh-elb01.plus.net [84.93.232.44]
9 30 ms 54 ms 32 ms community.plus.net [212.159.8.110]
Trace complete.
C:\Users\John>tracert 212.159.9.110
1 <1 ms 2 ms 1 ms tg582 [192.168.1.254]
2 23 ms 21 ms 23 ms lo0-central10.ptw-ag02.plus.net [195.166.128.196]
3 21 ms 20 ms 21 ms link-a-central10.ptw-gw01.plus.net [212.159.2.148]
4 20 ms 21 ms 24 ms xe-0-2-0.ptw-cr01.plus.net [212.159.0.248]
5 27 ms 21 ms 21 ms ae1.pcl-cr01.plus.net [195.166.129.1]
6 21 ms 21 ms 21 ms po2.pcl-gw01.plus.net [195.166.129.41]
7 28 ms 29 ms 27 ms gi5-8.ptp-cr01.plus.net [84.93.224.48]
8 29 ms 28 ms 27 ms vlan2657.ptp-elb01.plus.net [84.93.224.36]
9 28 ms 28 ms 30 ms community.plus.net [212.159.9.110]
If you gateway hop on to a ptn gateway you'd see something different again.
15-11-2014 12:05 AM
Having said that, I'm not convinced that this doesn't have a bearing on some of the issues being seen - if you follow all the negatives!
I can do traceroutes to each of the ntp servers and they are all the same number of hops. They are in different data centres. How does that come about?
15-11-2014 12:11 AM
15-11-2014 12:14 AM
15-11-2014 12:20 AM
All four IPs are definitely present in both ptw and pcl - you'll see the traceroute doesn't leave ptn/ptw or pcl depending upon where you are connected.
15-11-2014 12:31 AM
2 34 ms 40 ms 35 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 33 ms 31 ms 32 ms link-a-central10.pcl-gw01.plus.net [212.159.2.168]
4 34 ms 32 ms 32 ms xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5 32 ms 31 ms 32 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 32 ms 31 ms 32 ms cdns01.plus.net [212.159.13.49]
Trace complete.
Tracing route to cdns02.plus.net [212.159.13.50]
2 32 ms 32 ms 32 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
4 32 ms 65 ms 31 ms xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5 33 ms 32 ms 32 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 32 ms 32 ms 32 ms cdns02.plus.net [212.159.13.50]
Trace complete.
Tracing route to cdns01.plus.net [212.159.6.9]
2 34 ms 32 ms 32 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 32 ms 32 ms 32 ms link-a-central10.pcl-gw01.plus.net [212.159.2.168]
5 32 ms 32 ms 31 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 33 ms 32 ms 32 ms cdns01.plus.net [212.159.6.9]
Trace complete.
Tracing route to cdns02.plus.net [212.159.6.10]
4 32 ms 31 ms 52 ms xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
6 31 ms 31 ms 32 ms cdns02.plus.net [212.159.6.10]
Trace complete.
That would seem to trace to only the pcl ones. I guess on a ptn or ptw it will be different then. I'll have to try hopping and check it out again - a while since I have. But on pcl-ag03 it's working well so reluctant to hop atm.
In terms of problems - this "Connection Problems. Sorry SMF was unable to connect to the database.........."
has come up several times now whilst on 212.159.8.110 but I didn't get it once whilst on 212.159.9.110.
