Topic not going to last post today?
Fixes: 12
Very odd.  Today most of the topics I've visited are not going to the last post.  Even on a topic where I made a reply, the 'Blue box' is still on the first post (of 4)
No settings have changed in the last few days.  Anyone seeing a problem?
Maurice
Fixes: 21
Re: Topic not going to last post today?
Yes I noticed it earlier when it went to the first post instead
Fixes: 21
Yes, I've noticed it as well. At the first time I spotted it, I thought strange and thought it was probably something I'd done, but no, it is not jumping to the first unread post.
Fixes: 12
It does appear to be a sporadic problem and like you I initially thought that it was something that I was doing!  Yesterday I was not particularly active on the Forum but things did seem to work as expected.   However, this morning I've come across an instance that I can record.
Catching up, I went to the 192.18.1.x Topic that both yourself and @Townman have been responding on.   I was taken to the the top of page 5 (of 5), but checking, I could see that the 'blue box' indicating first Unread message was correctly set on Message 143 of 146.  I also see that this Topic had not been 'active' since the new site launch and thinking back, I believe that a number of other incidences I've seen fall into this category?  But I have seen it happen on newer Topics.
Maurice
Fixes: 21
Hi Maurice, it certainly is inconsistent,I've been having a look to see if I can spot a pattern, not research quite enough yet. As far as the 192.18.1.x thread goes it has been active in the last 24hrs. A poster posted yesterday and I've replied as did they and another from me. As a slight aside (but maybe related to the jump issue) I have 10 pages of that thread -146 messages, so question - how many posts per page do you have? I have 11 weird!!
Fixes: 21
In terms of inconsistency, taking this thread for example, when I hover over the post title the link given is
https://community.plus.net/t5/Community-Site-Feedback/Topic-not-going-to-last-post-today/td-p/1329103/jump-to/first-unread-message
but when I click it goes to the first post - that whether I do a left click or even a right click and Open in New tab.
Fixes: 21
Here's what I found with some other threads I tried it on - If I went to any particular post in a thread and marked it as new, when I next clicked on the Thread Title on a Board, it went to the post that I'd marked.
It's as though the system has forgotten which posts that I've read but not which Topics I've read. @Oldjim was complaining about it forgetting what had been read yesterday afternoon. Not forgetting of course that if there is a new post in a topic the topic will then show as Unread - unless I'm now totally confused.
I know one thing, I'm getting totally sick and tired of all these issues.
Fixes: 12
I'm seeing something similar.  In this Topic the 'blue border' was around my message 1,  when I had definitely read and posted later messages in the Topic.  I tried marking the topic as 'Read' but that didn't make any difference, but trying your trick of marking the post as 'New' moved the 'blue border' to the last post.  Retrying from the Forum page now took me correctly to the last post.
What should be the trigger to update the 'position in thread' trigger?
Like you I'm getting frustrated with these usability issues we report but see no action on.  I see the only PN staffer on-line today is trusty Bob P.
M
Fixes: 21
My guess is "something" has been updated. It's not been thoroughly tested and is having adverse effects. Now whether that is Lithium or Plusnet, we have yet to find out.
Oh, just to add, previously if you've read all the posts in a topic, even when you clicked on the title on the board list, it went to the last post, not the first.
jaread83
Fixes: 78
I think it takes you to the first of a series of unread messages and not the last message? For me it will highlight the first message that is marked as [NEW] in the subject on the post and I can read the replies after that.
Fixes: 12
@jaread83   I believe you are correct, where the 'last read' message is marked by a surrounding blue border. But in the last few days there have been a number of occasions where this is not happening - see my message No. 8.  It is (or has been) sporadic and therefore difficult to pinpoint specific instances unless ones focus is on the minutia of the process of reading the board rather than on the content?
Generally I'm moving away from using many of the new features because they are just not reliable enough in operation.  Sad fact because initially I was quite happy to see and make use of the new bits!
Maurice
Fixes: 21
That is what it is supposed to do Jack. It was doing it, but is no longer doing so. In every case I have tested today it is consistently going to the first post in the topic.
Also, previously, where one had read all the posts in a topic/thread it would go to the last post. It is no longer doing that.
jaread83
Fixes: 78
The weird thing is that nothing has been updated. There are other things at play too such as when a post is editted when you read the original, it marks it as unread (becuase there is new content).
I am going to guess you got the setting to 'jump to first unread post' option enabled too? That option only works from the board view. With the option disabled, you will be taken to the start of the thread when clicking any of the topics in the board. This option does not affect any other page such as the homepage which is just providing a quick view of whats going on recently.
Fixes: 188
Just thought I'd chip in and say it works fine for me and does as expected.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 21
Yes Jack, I have the option enabled and I know it only works from the Board view. But as I pointed out in message 6 you can see the link yourself and what it did.The OP has never been edited, and in all the other topics I have checked today, they were created more than 24 hrs ago, so the OP can't be edited.
