'Top fixers' panel
Fixes: 388
'Top fixers' panel
@JonoH Only a minor point, but has someone been fiddling with the forum? Somehow, the above list now shows only PN staff, whereas for as long as I can remember, it has previously shown ordinary Community members?
EDIT: @MisterW is on it - but with what looks like his total 'fix' count.
29 REPLIES 29
Fixes: 1,664
Re: 'Top fixers' panel
If you drill down into the top fix leaderboard, it looks like it’s sorting the fixes by ‘all time’ no matter what time range you click on. Huh
Thanks for flagging @jab1 I’ll raise for further investigation
RealAleMadrid
Fixes: 68
It has certainly changed, I was on the list a day or 2 ago and I'm definitely not in the all time list.😀
Fixes: 388
You are #28 on the list, @RealAleMadrid 😀
Fixes: 1,664
It looks like you can't see yourself on the list. I can't see me but by rights I should be second to dvorak. Cheesy
RobPN
Fixes: 15
Only second @Gandalf ? Roll_eyes
Fixes: 388
You can, @Gandalf - I'm #14 or 15 - can't remember which.😉
Fixes: 1,664
I know right? Outrage isn’t it? Tongue
Now this is odd. I logged out and I still couldn’t see me.
All these years earning fixes for nought...
[edit]
Also it looks like the mods/superusers are higher up on the top fix leaderboard that I can see because they’ve got a lot of ‘secret’ fixes from posts on their private boards.
For those who can’t see the private boards I suspect dvorak wouldn’t show at the very top.
Alex
Fixes: 13
Sounds like an update has been applied, now the Super Users (that should be two words not one) and the mods boards are now being included in some SQL queries now.
Fixes: 1,664
@Alex they’re not showing up if I log out my staff account so I don’t think that’s the case. Also if you toggle through the time periods, the order doesn’t change. I think the order is just set to All Time no matter what you select.
Alex
Fixes: 13
Thanks, just got my development hat on 😛. Sure you've tried logging out of your staff account and one with just standard permissions. If I can help with testing let me know.
Fixes: 1,664
Yep. Cheers, should be all good but I’ll let you know if we do need help testing.
Alex
Fixes: 13
Thanks, you know where I am if you need me,
Fixes: 251
@JonoH
I seem to recall when we were developing this forum's functionality, it was agreed (determined?) that staff** would not be included on the fixes leader boards, so as to place customer members at the top.
Am I imagining this?
We are all aware that a fair deal of the good customisation on here has broken over the years as Lithium (or whatever name they use this year) has slapped yet another part tested un-scoped change on the service.  Still waiting for the post editor to be restored to what it once was.
Please bring back @jaread83
**Edit - if this were the intention, then I can see that ex-staff might "muddy" this principle - see Chris!
JonoH
Fixes: 157
@Townman wrote:
@JonoH
Nope, that's exactly right.
I think I've a button that removes all fixes from an account so if we were precious about it we could likely rectify it, it's one of the reason why all new starters create a new forum account rather than use any existing one, and I'll nuke it if and when they depart.
 Jono H
 Plusnet Community Manager
