Testing paragraphs
grimples
Testing paragraphs
When i create or reply to a topic the text is always bunched together, making a new paragraph does not work. Do i need to use HTML. (i pressed enter twice for this line, see if it works)
5 REPLIES 5
Mav
Fixes: 518
Re: Testing paragraphs
Moderator's note:
Thread moved from General Chat to Community Site Feedback.
Forum Moderator and Customer
shutter
Fixes: 67
@grimples      ( using the default Rich Text ) .....
This is paragraph 1.
This is paragraph2. with one "enter" or "return" key press between para 1 and para 2
This is paragraph 3  with two "enter" or "return" key presses between Para 2 and 3.
This is paragraph 4 again, with two "enter" or "return" key Presses between para 3 and para 4
Seems to work for me ! ...
grimples
I was booooorn (one enter press) under a wandering (two enter press) staaaaaar
Fixes: 251
What device / browser are you using?
Small view port devices (such as a smart phone) use a different editor.  The full screen editor puts <p></p> around paragraphs, whereas the smaller screen editor simply puts <br><br> between paragraphs.
jaread83
Fixes: 81
@Townman is correct, mobile browsers use a 'plaint text' editor while desktop browsers use the 'rich text' version which adds html and other stuff.
If you are having issues with the mobile browser version, you could always trick the forum into thinking you're on desktop. Most mobile browsers have a 'request desktop version' option, enabling this will trick the forums into giving you the rich text editor. Hope this helps!
