Smilies and Java
pierre_pierre
Smilies and Java
is the machine at PN having a hickup or is it that the Sender hasnt got Java, but recently I am getting a lot of postings where it has got the script but not the smilie i.e. ":d" instead of  Grin and  in several cases the complete"jav-jav" sentance
14 REPLIES 14
pierre_pierre
Re: Smilies and Java
just found another,.javascript:replaceText(' Smiley Smiley', document.forms.postmodify.message);
Smiley
shutter
Fixes: 67
:)happens when you don`t put a space after the smiley :)like this one ;Dand this one  Roll_eyes  but this one should be ok  Roll_eyes
pierre_pierre
thats probably correct, but what about the long one with Java  right up to smiley?  Huh
Colin
More than likely someone's either dragged the icon to the text area or copied the Link location and pasted it in to the text box.
jelv
Fixes: 10
javascript:replaceText(' ???', document.forms.postmodify.message);
Huh
Dragging seems a good bet as Colin has suggested
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
what about this one
sign up and plug pro 😉
jelv
Fixes: 10
Quote from: pierre_pierre
what about this one
😉 is one the usual ways to key wink - this forum uses
- someone must of keyed it instead of clicking the wink icon.
Edit: Sorry for anyone that saw the false starts I had trouble stopping it being changed to the icon.
pierre_pierre
tried that
yes its possible drag
the person was a new user to these forums
jelv
Fixes: 10
You're right - it is a drag when people do things like that!
jelv
Fixes: 10
Moderators: I suggest this topic is moved to resolved bugs.
chillypenguin
If you point out the post we can get it sored for them.
Chilly
chillypenguin
mod:note
Moved to resolved, as never a bug in the first place.
pierre_pierre
I tried it on  Wink and got a page full of java nonsense
Agreed Resolved
Colin
😉 isn't defined as a smiley on these forums... but if enough people are using it to be a problem, I believe it's a 30 second job to fix in the Admin panel.
