Show unread posts since last visit
- Feedback
- Community Site Feedback
- Show unread posts since last visit
07-04-2007 5:20 AM
I use this sort of facility on many fora but dont see it here. You can view all posts (which is built so that it doesnt flush after the visit) and you can go to individual boards and click on 'New' topics but I dont see a way to have an overall look for posts since the previous visit.
I presume I havent looked in the right place but perhaps the SMF design is not suited to it.
4 REPLIES 4
Re: Show unread posts since last visit
07-04-2007 5:43 AM
I had better make it clear I was thinking about a list of topics across the boards which have the 'New' icon attached.
07-04-2007 11:14 AM
I'll look to getting the link added back in... in the meantime, if you go to index.php?action=unread it hsould be what you are looking for
07-04-2007 12:55 PM
Quote from: Colin I'll look to getting the link added back in... in the meantime, if you go to index.php?action=unread it hsould be what you are looking for
That's what I use - very useful - but can you make a marginal change to the page name to be different to that used on the PUG site as IE uses that to name the shortcut and as it conflicts with PUG one, it will overwrite it if allowed. Maybe put a colon at the end or an extra space or some change of phrase to make it not the same? Ta.
10-04-2007 9:30 AM
Raised as a bug.
Please see http://community.plus.net/forum/index.php?topic=33.0
Locked
Locked
Kelly Dorset
Ex-Plusnet Jobsbody
Ex-Plusnet Jobsbody
