Security certificate (SSL)
7up
Fixes: 20
Each time i visit the forum on my phone i get a nag screen or 5 about the security certificate. I don't really take much notice of what it says and just click continue. Anyway i assumed it was the phone playing up... until i visited on my netbook and got more similar prompts (again i just continued).
It doesn't happen on the desktop computer... so i'm assuming that there may be a bug with the SSL certificates somewhere that someone needs to look into...
7up
3 REPLIES 3
bobpullen
Fixes: 330
Re: Security certificate (SSL)
Thanks for raising. We're aware of this particular issue, and I believe a fix is scheduled for early this week.
bobpullen
Fixes: 330
This should be sorted now. @7up, are you able to confirm?
7up
Fixes: 20
Nothing so far so it looks like it.. will let you know if this gremlin returns.
