Searching this forum
Oldjim
Fixes: 63
In view of the fact that the advanced search system doesn't work properly (I am not sure about the simple search either  ::)) the following may be of assistance.
If you put  the following in the Google search window followed by the search terms it works much better and you can use Google Advanced Search as well
site:community.plus.net/forum
