SMF version
jelv
Fixes: 10
SMF version
In line with the present practice in phpBB, would it not be better if the version number was omitted from the "Powered by SMF" in the footer of these forums? If a new version of SMF is released to fix a security hole, I rather think displaying the old version number until you can get it fixed is inviting trouble!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
8 REPLIES 8
Colin
Re: SMF version
IIRC, we aren't allowed to remove the version... but I'll check
jelv
Fixes: 10
Re: SMF version
Reading the SMF License and Copyright pages on the SMF website I would say that you cannot remove the bit that says "SMF © 2006-2007, Simple Machines LLC" which is understandable.
Colin
Re: SMF version
Removed... although there was a bit of a hairy moment  Undecided
jelv
Fixes: 10
Re: SMF version
Have you seen http://www.simplemachines.org/community/index.php?topic=172746 ?
Colin
Re: SMF version
No. I looked this morning myself to see if you could change it, found it was in the language file, didn't produce the horrible nasty warning and left it.
artificer
Re: SMF version
i spend a lot of time on smf fora and one feature i use a lot is the up/down button at the head and foot of pages. it helps when, having read to the end, the user wants to get to the top quickly without having to use the slide bar.
please, pretty please, can we have a go down and a go up button?
billbo
Re: SMF version
I'll second that one.  Cool
When returning to a thread I often have to go to the top to see the previous few post just to remind myself of the gist of the discussion.
artificer
Re: SMF version
yerst, well.  we don't got it yet.
