Report to Mod Link
- Feedback
- Community Site Feedback
- Re: Report to Mod Link
Report to Mod Link
04-07-2007 1:25 PM
Though a Report to Mod link was mentioned in this topic it has just occurred to me I have never seen one of these in the Community forums. Is this something that appears for mods/admins only but not for members. If this is the case it is a bug.
David
David
David
8 REPLIES 8
04-07-2007 1:30 PM
04-07-2007 1:30 PM
It's for everyone. It gives you the opportunity to report a post which you feels violates the forum rules.
04-07-2007 1:49 PM
Quote from: Kelly You mean this link?
<image removed>
Indeed I do, unfortunately one is not shown on my displays. Having seen where it should appear I expect this is due to it being omitted from the alternative code that shows ip: Logged to lessor mortals.
@Kelly: please refer to PM I've sent concerning the image (I see it's been actioned - thanks).
David
David
04-07-2007 1:56 PM
That smells like a bug to me. I presume you are just seeing "IP: Logged", which is what you get when you are a guess?
Kelly Dorset
Ex-Plusnet Jobsbody
Ex-Plusnet Jobsbody
04-07-2007 2:13 PM
Quote from: Kelly That smells like a bug to me. I presume you are just seeing "IP: Logged", which is what you get when you are a guess?
That's correct, that line just says "ip: Logged" at the right-hand margin. All that is in front of this is white space.
David
04-07-2007 3:31 PM
Yep - I get exactly the same as spraxyt
04-07-2007 3:41 PM
Fixed.
04-07-2007 4:20 PM
Yes, getting the link now.
Thanks, David
Thanks, David
David
