Quick edit not working under FF?
zubel
Just tried to edit one of my own posts using "quick edit".
It brought up the edit screen, but when I hit "Save" my post was not changed at all.
Tried refreshing, clearing cache etc - no joy.
Using Firefox 2.0.0.6.
B.
28 REPLIES 28
James
Re: Quick edit not working under FF?
Let me try. I think it works for me.
James
Modify does.  Quick edit doen't.  I'll let Colin know.
Liam
Brings up a green bar that says "Loading", but doesn't load anything?
Then the edit doesn't save.
Hmm...
Loombucket
Interesting...
I was just about to post this problem having experienced it myself a couple of times when I saw this thread.
FYI, it doesn't appear to be version-dependent - two of my machines run FF 2.0, the other runs FF 1.5 and they all do it.
Peter_Vaughan
Firebug on FF2 show an error
element has no properties
getInnerHTML(null)script.js (line 268)
onDocReceived_modify(Document )xml_topic.js (line 78)
onreadystatechange()script.js (line 36)
[Break on this error] if (typeof(element.innerHTML) != 'undefined')
So may be browser related javascript problem.
Kelly
Fixes: 9
added to bugs list.
Kelly Dorset
Ex-Broadband Service Manager
hulls
I run IE 7 and the same problem applies
Simon_M
I take it that this is still somewhere on the bugs list?
Peter_Vaughan
Quote from: Simon
I take it that this is still somewhere on the bugs list ?
http://community.plus.net/bugs/ or click the bugs link at the top of the page Wink
Simon_M
Hmm. Ok, I assume you two have your tongues firmly in your cheeks.  Undecided
Let me be a little more specific.
In response to:
Quote from: Kelly
added to bugs list.
I take it this is still on Plusnet's internal bugs list? Has an assessment been made as to whether it's fixable? Is a fix in a work schedule? If it's going to be a long time or require significant resource, is it an easy job to remove the option from the screen until it can be made to work properly?
It must be very frustrating for new users to keep trying it & finding that they can't seem to get it to work.
26/09/07 Quick edited to prove it now works.
Assos
Doesn't seem to work under safari either...
MikeWhitehead
http://modxcms.com/forums/index.php/topic,12782.msg87572.html#msg87572
That's apparently a fix for it. Maybe one of the PN staff can have a skim over the post, test it on the beta forum and see if it fixes the problem?
EDIT: Just noticed this is for MODx, so don't know what I was thinking Tongue
Kelly
Fixes: 9
It's a bug Tam introduced when he was tweaking something with look and feel.
Kelly Dorset
MikeWhitehead
Bad Tam! No dinner for a month Tongue
