Posts deleted?
Oti78
Posts deleted?
I posted  a reply in the Fibre broadband section and it disappeared.
I retyped it and it happened again.
Can you please check and let me know if it has been flagged by the spam filter?
2 REPLIES 2
Alex
Fixes: 13
Re: Posts deleted?
It's possbile, I assume they have to move it back into the production forums if they're happy it is not. Seen it before.
On your current post I would suggest you choose the 'Report to Moderator' function, which will directly send a message to them. If they're happy then they will release it.
Fixes: 1,493
Re: Posts deleted?
I've released the post.
