Post editing
MrFraggle
Post editing
Can you not quote a particular post you want to reply to in a thread or even edit your own thread/post on these forums.
7 REPLIES 7
PeterLoftus
Fixes: 5
Re: Post editing
Yes you can (there's quote option in the edit dialogue) as above but it is against forum rules ( sort that out mods)
If you want to edit your work click the post options box
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Oldjim
Resting Legend
Fixes: 63
Re: Post editing
There is a time limit on editing - may be 24 hours but I can't remember
Regarding quoting - if you click on reply under the post you wish to quote the option works
PeterLoftus
Fixes: 5
Re: Post editing
@Mav so how can I demonstrate my point?
Mav
Fixes: 518
Re: Post editing
Click the Reply button in the post you wish to quote then you can click the Quote button.
It's only quoting the full previous post that is against the forum rules as in Peter's example above (unless the full quote is at the top of a new page).
I think there is a time limit of 24 hours in which a post can be edited.
Forum Moderator and Customer
Oldjim
Resting Legend
Fixes: 63
Re: Post editing
like this
MrFraggle
Re: Post editing
Ah thanks mate.
Mav
Fixes: 518
Re: Post editing
Moderator's note by Mike (Mav): I have changed the fix to post #5
