Post editing
rongtw
Fixes: 12
Post editing
I have just realised someting else is missing from new forum Sad
on old forum if you replied to a post and someone else did at same time , we used to get a warning than while you were typing another post appeared , which gave you a chance to edit your post ..
We seam to be missing this on Lithium Undecided
31 REPLIES 31
Oldjim
Resting Legend
Fixes: 63
Re: Post editing
we know and despite a lot of gripes during beta testing it couldn't be fixed
jaread83
Fixes: 81
Re: Post editing
This is something we flagged up early on in the project as its very useful to know if someone else replied to a thread during the time you were composing a reply.
The system currently doesn't do this so we found an idea from other users requesting this and we all upvoted or commented on it.
http://community.lithium.com/t5/Product-Ideas/quot-New-post-made-while-composing-quot-notification/i...
rongtw
Fixes: 12
Re: Post editing
JIM i thought we were STILL Beta testing !
MauriceC
Resting Legend
Fixes: 17
Re: Post editing
Access to that part of the forum not allowed.  Undecided
rongtw
Fixes: 12
Re: Post editing
Another SILLY thing which i find annoying , when i reply to a Post ,,,,,, Whats the point of clicking GO TO YOUR POST
when i know what i just posted and can see it Crazy2
rongtw
Fixes: 12
Re: Post editing
Maurice SEE i typed a reply when you did same !! no warning
PS yes i saw link didnt work it said LITHIUM Cheesy
Anotherone
Champion
Fixes: 21
Re: Post editing
BECAUSE it marks the post as Read TongueGrin and you can also see if someone else beat you to a post Funny but you can also check again for typos, which despite checking previously I've found sometimes I still have some Embarrassed
Mav
Fixes: 518
Re: Post editing
Also you can click Reply to a post earlier on in the thread so as to make quoting easier and you are returned back to the post to which you replied which could mean your reply post is not actually visible.
Forum Moderator and Customer
rongtw
Fixes: 12
Re: Post editing
On my local Paper forum , when you reply to a Post it simply puts the post under the post i replied to slightly off set  Smiley  and no space between posts
  Thumbs_Up siimple and easy
SEE below ,, easy to use forum
spraxyt
Resting Legend
Fixes: 75
Re: Post editing
Personally I hate such threaded view forums. Replies often end up in the wrong thread, but maybe in some cases one would never know. Grin
David
jaread83
Fixes: 81
Re: Post editing
We had the option of doing this from an early stage of development but it was universally hated. There was even an option in the system to convert the entire community over to do this for any user who wanted to have it displayed this way. We asked for this to be removed as most would see the forums in the normal way and it would get confusing as people would just hit the reply button anywhere in the flow to create a response to the last post.
Oldjim
Resting Legend
Fixes: 63
Re: Post editing
http://forums.thinkbroadband.com is an example of that and personally I always use flat mode
If you look at this thread http://forums.thinkbroadband.com/plusnet/t/4480654-plusnet-well-do-you.html?o=31&vc=1 in flat mode and threaded mode you can see the effect
rongtw
Fixes: 12
Re: Post editing
Sorry Jaread83 ,,,, BUT at the moment THIS forum is universally hated in its present form !
Anotherone
Champion
Fixes: 21
Re: Post editing
That's not true with regard to the points you've recently made. There are "features" missing that we want adding, and there's a lot of good stuff some of which needs some "fine tuning" to put it politely. There's things like the Spam filter that need fine tuning (addressed elsewhere) and there are a limited number of things that need changing. There are of course the reported bugs that need fixing - but were were reminded about all the bugs there were with SMF when it was first introduced in 2007 Shocked - though I still reckon there are more bugs here Tongue
The only thing I can think of off the top of my head that is totally abysmal at present is the search engine.
Edit: And the "work-around" to your original issue until the correct feature is provided, is to "View discussion in a popup" just before posting to check there are no new posts.
