Plusnet Forum "Connection reset by peer" error
jelv
Fixes: 10
Re: Plusnet Forum "Connection reset by peer" error
Don't think so. Had you not seen http://community.plus.net/forum/index.php/topic,103382.msg1053872.html#msg1053872 ?
Isn't community hosted in Sheffield (mbs is in London)?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Kelly
Fixes: 9
Same type of loadbalancers, I was meaning.
Kelly Dorset
Ex-Plusnet Jobsbody
Midnight_Caller
@Kelly, What type of loadbalancers are you using?
This error didn't happen too frequently over the Christmas break,
but since the new year it now happens so often that it is becoming a real nuisance !  Angry
Is Chris Coates still looking into the causes of this error ?
Kelly
Fixes: 9
I believe so.  Problem ID for this is 79043.
Kelly Dorset
Ex-Plusnet Jobsbody
This error has occurred so frequently today that it has made navigating this forum infuriating !  Angry
At times it has been failing perhaps three out of every five clicks on links  :'(,  when it is normally < 3% of clicks.
No other website is giving me this problem (other than Plusnet's http://www.mybroadbandspeed.co.uk/).  Roll_eyes
ejs
Aspiring Hero
Fixes: 25
This forum hasn't been any worse than usual for me today.
Kelly
Fixes: 9
I think the problem is mostly unnoticed unless you are running behind a transparent proxy (Like Purleigh is using) or using a browser like Opera which does proxying.    Or uploading a file perhaps!
Kelly Dorset
Ex-Plusnet Jobsbody
avatastic
To replicate:
Go to a list of posts (a forum index)
Run down the list and middle click each link as quickly as possible.
The last few will fail.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
ejs
Aspiring Hero
Fixes: 25
You might notice more problems if you check your firewall logs, or possibly watch all the duplicate ACKs etc. in wireshark.
