Plusnet Forum "Connection reset by peer" error
- Feedback
- Community Site Feedback
- Re: Plusnet Forum "Connection reset by peer" error
![](/skins/images/CFCAB4E4C1E82474BDA2C23F66F76F4B/responsive_peak/images/icon_anonymous_message.png)
07-12-2013 4:30 PM
This ONLY happens while viewing this Forum, and usually no error messages appear on Firefox, but sometimes says the connection was reset.
Over the past few days, I have completely rebuilt the internet facing side of my home network, including a different modem (SNR tweaked Billion 7800 in bridged modem mode), a self built pfSense Linux router, a new 'dnsmasq' primary caching DNS server, and a 'squid3' transparent caching http proxy. The result is quite impressive, with my SamKnows whitebox reporting that my "Website Load Times" have dropped from an average 670ms to 55ms - which is pretty good for a 6.7Mbps ADSL connection with a current interleaved 40ms latency.
With this new setup, I have been trying everything that I normally do on the internet to try and break it, hammering every website on maximum settings, but so far it has all worked perfectly, no errors reported, nothing untoward in the log files, and less than five errors per day on the ADSL modem.
However, the http proxy now captures those occasional Plusnet Forum page hangs -
![](http://www.purleigh.f9.co.uk/forum/Forum%20connection%20reset.jpg)
Clicking on the link to the problem page URL ALWAYS makes the page reload correctly, and as I said before this is ONLY happening on the Plusnet Forum, and probably less than 1% of forum page views.
Any thoughts ?, or is this just another anomaly of the Plusnet Forum website ?
![Huh Huh](/html/@3681646702FDFD32BCA97E2E5F1BDDD5/images/emoticons/huh.gif)
07-12-2013 5:02 PM
Do you log packets from these IPs when you're browsing the forums? It should be pretty obvious that something within Plusnet isn't setup properly.
07-12-2013 5:37 PM
Most of the Plusnet dropped packets seem to be from mail servers (e.g. 'mailc03.plus.net') - despite nothing being setup that would cause packets to be dropped other than unsolicited stuff bouncing off IPv4 NAT.
I will try a packet capture on the router's WAN interface (awesome feature !), and see what turns up. Is it always port 44340 ?.
07-12-2013 6:13 PM
07-12-2013 6:21 PM
17:38:44.815276 AF IPv4 (2), length 71: (tos 0x80, ttl 55, id 23886, offset 0, flags [DF], proto TCP (6), length 67)
community04.servers.plus.net.44340 > purleigh.5799: Flags [P.], cksum 0xaabb (correct), seq 1677150141:1677150168, ack 1109273889, win 381, length 27
17:38:55.979385 AF IPv4 (2), length 71: (tos 0x80, ttl 55, id 41591, offset 0, flags [DF], proto TCP (6), length 67)
community04.servers.plus.net.44340 > purleigh.14792: Flags [P.], cksum 0xbfa3 (correct), seq 3037186070:3037186097, ack 1871287014, win 290, length 27
17:39:13.467647 AF IPv4 (2), length 71: (tos 0x80, ttl 55, id 20417, offset 0, flags [DF], proto TCP (6), length 67)
community04.servers.plus.net.44340 > purleigh.2434: Flags [P.], cksum 0x507c (correct), seq 3000861306:3000861333, ack 505637402, win 1002, length 27
17:39:27.820012 AF IPv4 (2), length 71: (tos 0x80, ttl 55, id 23887, offset 0, flags [DF], proto TCP (6), length 67)
community04.servers.plus.net.44340 > purleigh.5799: Flags [P.], cksum 0xaabb (correct), seq 0:27, ack 1, win 381, length 27
07-12-2013 9:22 PM
and there were no corresponding 'community server' firewall entries or spurious port 44340 packets detected on the WAN.
10-12-2013 10:53 AM
As I said originally, I think this problem has always existed while using a normal web browser on this forum, but because the browser would occasionally hang and usually not report an error, doing a refresh would allow browsing to continue. Since I have added a transparent http proxy server to my network, it seems less forgiving and throws up the error page and reports what went wrong.
Any ideas from the DCT staff ?
10-12-2013 11:13 AM
Ex-Broadband Service Manager
10-12-2013 1:38 PM
The forum, its database back end, probably PHP too are most likely in need of a major update/overhaul but who has time to do that?
12-12-2013 10:49 PM
![Cry Cry](/html/@EF02202129013B5A91517CA3B2B0F58A/images/emoticons/cry.gif)
15-12-2013 7:17 AM
[tt]traceroute to 212.159.9.110 (212.159.9.110), 30 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 1.453 ms
2 lo0-central10.pcl-ag08.plus.net (195.166.128.189) 26.201 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.190) 20.452 ms
4 xe-9-1-0.pcl-cr02.plus.net (212.159.0.222) 20.524 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 20.244 ms
6 po2.pcl-gw01.plus.net (195.166.129.41) 20.549 ms
7 gi5-8.ptp-cr01.plus.net (84.93.224.48) 28.498 ms
8 vlan2658.ptp-elb02.plus.net (84.93.224.45) 28.892 ms
9 community.plus.net (212.159.9.110) 29.077 ms
10 community.plus.net (212.159.9.110) 28.371 ms[/tt]
[tt]traceroute to 212.159.8.110 (212.159.8.110), 30 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 1.446 ms
2 lo0-central10.pcl-ag08.plus.net (195.166.128.189) 21.870 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.190) 21.114 ms
4 xe-9-1-0.pcl-cr02.plus.net (212.159.0.222) 19.965 ms
5 ae1.ptw-cr02.plus.net (195.166.129.2) 21.066 ms
6 ae2.ptw-cr01.plus.net (195.166.129.4) 20.265 ms
7 te9-4.ptn-gw01.plus.net (195.166.129.33) 21.067 ms
8 gi5-1.peh-cr02.plus.net (84.93.232.61) 38.378 ms
9 po5.peh-cr01.plus.net (84.93.232.16) 28.922 ms
10 vlan2658.peh-elb02.plus.net (84.93.232.53) 28.744 ms
11 community.plus.net (212.159.8.110) 28.427 ms
12 community.plus.net (212.159.8.110) 30.054 ms[/tt]
Based on those traceroutes, I've currently set mine to only go to 212.159.9.110, which I'll probably should change once I end up on a PTN / PTW gateway. I'm not sure if it's made any improvement, because I just tend to write off any minor or occasional issues as being due to my line.
16-12-2013 9:25 AM
16-12-2013 12:38 PM
24-12-2013 3:31 AM
Still never seen this problem on a non-Plusnet website.
24-12-2013 8:32 AM
- Feedback
