Page Not Found - typo
pberry
If you try and look up a page that doesn't exist on the Community Site, you get a nice 404. However it contains a typo. See the right-hand menu section:
page not found
have you tried using the search form above to find what your looking for?
1) Should be sentence caps.
2) It's "you're" and not "your".
Thanks.
5 REPLIES 5
Kelly
Fixes: 9
Re: Page Not Found - typo
Isn't that an IE setting?
Huh
Kelly Dorset
Ex-Broadband Service Manager
Kelly
Fixes: 9
Tools > Internet Options > Advanced > Browsing > Show friendly http error messages  ?
Kelly Dorset
pberry
Quote from: James_H
Why don't I get custom 404's?
I only get the M$ default....
Seems it's certain directories on here. For example: http://community.plus.net/comms/blah
spraxyt
Resting Legend
Fixes: 75
It works for me (XP+IE7) but it's the "…search form below to …" in my case.
David
pberry
Quote from: spraxyt
Yep, should say "below", since the search box is located underneath that text.
