Old, read, posts appearing as 'new'
Fixes: 382
@James_B Starting early this morning, posts I have read keep reappearing in the 'unread' list - but randomly - i.e. a post made at 10.00 AM will show as unread, even though I read it around that time, but later posts in the same topic - also read - do not.
35 REPLIES 35
Fixes: 382
Re: Old, read, posts appearing as 'new'
See screenshot:
Fixes: 382
And again, to prove it is reproducible:
Fixes: 382
Also, probably related, notification of replies to subscribed topics are randomly not appearing in my notification feed.
Fixes: 382
And another 'UNREAD POSTS' feed - including ones I made!!
Fixes: 244
This is an intermittent issue, seen before which I suspect is related to multi-service-instance synch failures.  Or to put it in simple language the right hand does not have a clue about what the left hand did.
These are fundamental considerations with multi -instance services; how does whichever service instance responds to a request know it is dealing with current data?
I suspect similar belies the variable notification count issue, reported elsewhere over 3 months ago, now on “escalation” with the networks team.
Fixes: 382
Fair enough, @Townman , although I don't recall it.
So this is likely to be as long-running and aggravating as the other issue you refer to?
James_B
Fixes: 16
Thanks for reporting this and sharing the screenshots, @jab1
As @Townman mentioned it's likely related to an open ticket we have with the platform provider so I'll add your examples to it.
James
Fixes: 382
Cheers, @James_B . Also, as mentioned, notifications of replies to subscribed topics are not appearing in my notification feed, randomly - e.g. your reply above.
Fixes: 244
@James_B
Today I am seeing posts I read on the 24th reported as being new.  Is there any helpful evidence one can gather for you?
To the point, the one I just saw was on the SU board … which 15 or so minutes ago reported zero unread posts.
James_B
Fixes: 16
Hi @Townman,
There was some scheduled maintenance completed yesterday so could be related.
Please could you monitor and grab a screenshot if it persists?
James
Fixes: 244
Hi @James_B
For a starter, my post above just displayed as new, along with yours which is correctly flagged as new.
Fixes: 244
FWIW it now does not show as new … will see if this changes again.
How difficult is it for these folks to look at service multi instance inconsistencies?
One rashly presumes that this service has multi instances over a distributed synchronous database?  If not then the theories of what’s going on are irrelevant, but if correct then the developers ought to be able to run a reference query on each instance and verify that they get the same result.
Either there’s a sync issue or a cache issue.  Someone with knowledge of the architecture ought to have a good clue by now of the circumstances which might lead to this broken behaviour.
Fixes: 382
FWIW, the 'notification' error has not been resolved. Neither has the repeat listing of read posts being relisted as new - for me, anyway.
Fixes: 382
@James_B Whatever Khorus did (or didn't) has had no effect- I am still seeing read posts randomly being shown as unread, and notifications not appearing in my notification feed, eve though the pop-up is still working, rather pointlessly, as there is no way to link the pop-up to a post.
