Notification issues
Fixes: 1,495
Notification issues
Is anyone else seeing notification issues today? It's just taken 2 hours to be notified of a response to a topic in the 'My Notification' feed and still haven't received and email.
5 REPLIES 5
MauriceC
Resting Legend
Fixes: 17
Re: Notification issues
Nothing noticeable so far.  @dvorak
Fixes: 1,495
Thanks @MauriceC
I've just had a flood of emails and notifications under 'My Notifications' so looks like something has had a kick.
Juanita
I want to turn off notifications I’m receiving for posts that are no longer relevant! No clue how to do this.
Fixes: 1,495
if you go into the thread that you're getting notifications for there's a drop down called 'Thread options' click that and then select 'Unsubscribe' and you'll no longer get notifications.
198kHz
Fixes: 42
I didn't respond to the OP as I'd not encountered the issue.
However, in the last few minutes, while perusing unread posts, I found four or five for which I should have had notifications
BT technician (Retired)
