Modifying a post
gleneagles
Aspiring Legend
Fixes: 17
Modifying a post
How long do you have to modify a post ?
For example I asked a question under the Linux section and the problem is now solved so I wished to return to my initial post and add the word  Solved to the title but the option to modify was no longer there.
We are born into history and history is born into us.
4 REPLIES 4
pwatson
Re: Modifying a post
w23
Fixes: 4
Just report the first reply to a moderator (using the report to moderator link) and request [SOLVED] be added to the title - I think that would work (have patience though the moderators may have other things to do).  Smiley
Call me 'w23'
Chris
Legend
Fixes: 169
This is one of the benefits of the upcoming changes to the forum Wink
Mav
Fixes: 518
@gleneagles. I have changed the title for you Smiley
BTW it's 24 hours before a post can no longer edited.
Forum Moderator and Customer
