Messy SMF Icons
chillypenguin
Messy SMF Icons
Some of the icon look a little messy.
Such as new thrread and new poll.
Also some of the small icon have no text description.
Chilly
12 REPLIES 12
Liam
Re: Messy SMF Icons
Yup, we're aware of this.  Not all of the buttons have been skinned yet.
Neil_A
Re: Messy SMF Icons
'Post reply' text is very small for my eyes.
Kelly
Fixes: 9
Re: Messy SMF Icons
Merging together SMF icon complaints.
Kelly Dorset
Ex-Plusnet Jobsbody
Kelly
Fixes: 9
Re: Messy SMF Icons
Added as bug.
Kelly Dorset
Ex-Plusnet Jobsbody
pberry
Re: Messy SMF Icons
I only discovered what the "notify of replies" icon did by looking at the alt: could do with having supporting text like the "post reply" icon does.
Graham_W
Re: Messy SMF Icons
Quote from: James_H
Again, not so much a bug, as a preference - I find it hard to distinguish between the 'no new posts' and 'new posts' icons on the index page.
Any chance of making the icons more contrasting?
Sorry to reply here but the 'Quote' icon and the 'Quick Reply' box are missing
in the Wishlists topic.
Subject concerned 'Recent unread topics'
James you are guilty of scanning the post and missing the point! The point about dragging the Address field to the Links bar in IE is an automated process in IE but since it uses the page name to index it, it will erase the PUG one because that carries the same name. The user has no opportunity to edit the name of the link created, only to cancel or go ahead.
I have created one now by creating an Internet link on the Desktop and then dragging it to the 'Links' bar. The Name field was one that I typed in to create it, so no problem there. If you use IE try it yourself (the former 'quick' way) to see what I mean.
HTH and clarifies.
Graham_W
Re: Messy SMF Icons
Quote from: Graham
Thanks for the reply.
See quoted text, James, otherwise I'd have done a rename but not possible
I agree there are a number of ways of getting around it but it is a bug*** none the less and the non-techy types could lose their PUG link quite easily.
Graham_W
Re: Messy SMF Icons
Quote from: James_H
The rename *is* possible though! Its just that you have to rename the existing one, since you don't get the chance to edit the new one as its created. Wink
Thanks again, James.
I must admit that that idea must have eluded me! I couldn't think what to do to avoid losing the current one when trying to drag the new one to the 'Links' bar.
Kelly
Fixes: 9
Re: Messy SMF Icons
New icons in place.  Look a bit better?
Kelly Dorset
Ex-Plusnet Jobsbody
Penny
Fixes: 9
Re: Messy SMF Icons
Quote from: Kelly
Yes Smiley
A sharper range of smileys (more definition) would be good though, also.
I don't suppose there's any point in asking (again) for a border each side of the posts, to separate them from the wide white margins?
Even a very thin border would do  Roll_eyes
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Kelly
Fixes: 9
Re: Messy SMF Icons
Mitch should be producing an alt style sheet for the forums when he gets a chance.
Yeah, nicer smilies would be good too.    Cool
Kelly Dorset
Ex-Plusnet Jobsbody
Colin
Re: Messy SMF Icons
Some of the images are still not right: http://community.plus.net/forum/Themes/plusn/images/english/markread.gif being the main one
