Login Problems
FIXED- Subscribe to RSS Feed
- Feedback
- Community Site Feedback
- Login Problems
04-04-2017 5:22 PM - edited 04-04-2017 5:28 PM
For months I have been having trouble logging into the forum on this account I am posting with. I have been trying to log in for 3 days to no avail. The error message is attached, can someone look into it for me please? never had this trouble on the old forum. If password and username do not match then I should not be posting this thread because it has the same password I have used for a few months it has no changed but sometimes I get in sometimes I do not and I have tried changing password before and still get this error.
Fixed! Go to the fix.
Re: Login Problems
04-04-2017 5:29 PM
Hi Steve,
I am sorry to hear about the issues you are having logging into the forum.
I think I know exactly what the issue is here. The old forums allowed the same login name (but used the email address to login) and I can see that there is another 'Steve' in the user list.
Leave this with me, I will rename this other Steve as they registered in 2007 and haven't posted since.
04-04-2017 5:31 PM
Hi @Steve, this has been fixed now. You will no longer have any issues logging in with your account as I have renamed the other account to Steve3.
Let me know if this works for you now.
Re: Login Problems
04-04-2017 5:34 PM
Hi @jaread83 Thank you for the help I have been tearing my hair out, at first I thought it was just gremlins then I played around with 2 browsers, even a different device but with the same result. I got lucky being able to post this I will let you know how I get on over, logging out.....now.....lol
Re: Login Problems
04-04-2017 5:38 PM
Managed to log back in first time. Thanks for the help much appreciated
Re: Login Problems
04-04-2017 6:34 PM
Re: Login Problems
27-04-2017 1:32 PM
Re: Login Problems
27-04-2017 1:57 PM
Have you tried a different browser just to test? What browser are you using? Do you have any browser extensions that is blocking javascript at all?
Re: Login Problems
27-04-2017 8:43 PM
Thanks for your remarks. I am using only Firefox as a browser. Anyway it all works again tonight. Most peculiar?
Colin.
Re: Login Problems
27-04-2017 8:50 PM
Re: Login Problems
28-04-2017 9:13 AM
Re: Login Problems
28-04-2017 12:29 PM - edited 28-04-2017 12:31 PM
Thanks for that.
There is something going on. More often it seems to light up a green "halo" round the "Head" and twitches the image when clicked and no text. Other times it brings on the desired text as wished. This would look like a fault at this end. Any ideas from your end?
Re: Login Problems
28-04-2017 1:58 PM
I would suggest putting your browser into 'safe mode' and try it again. Safe mode will disable all browser extensions and will act like a fresh install.
I would also check the version of your browser and make sure it was up to date.
You could also try a 'private session' which would give you a browsing session that has no cache or browser history.
It sounds to me like an extension is interfering with your browser in some way. As a last resort, I would reinstall the browser as it could have a corrupted file in its core... but as I said - definately a last resort. There are ways to backup your extensions and bookmarks before you do that which I would recomend you do before taking any drastic action.
You could do a test of your browser here: https://www.whatismybrowser.com/
That site will detect whether or not your javascript is running, flash installed and a bunch of other things.
Hope this helps!
Re: Login Problems
29-04-2017 12:15 PM
Thanks for the comprehensive to do's! I tried the browser checkout. The only thing it noted was Java not installed. The rest were up to date! Just now, the clicking of my "face" is working OK.
I do not have any significant browser extensions in play.
I might try putting Firefox 53 into safe mode and see what that does.
Re: Login Problems
29-04-2017 12:30 PM
