Login Button
dejjones
Login Button
When accessing this site, on the home page, http://community.plus.net/
the login button at the top is almost obliterated by the "community" logo.
Thought this might be a problem with my browser, but it does occur with both IE7 & Firefox 2.
Minor problem but for newcomers it could take them a while to find out how to login.
9 REPLIES 9
Chris
Legend
Fixes: 169
Re: Login Button
Do you have a screenshot of this? I've just tried varying resolutions including the lowest this PC will go to (800*600) and it still doesn't overlap.
MikeWhitehead
Re: Login Button
I'm guessing its 640x480. The width of the column is set to 702px IIRC (random, I know!), so if its 640x480 then it will cause distorted views.
dejjones
Re: Login Button
Screenshot attached as requested.
I believe my screen resolution is 1280 by 1024
Chris
Legend
Fixes: 169
Re: Login Button
Ah, I think this is because you have the text size set quite high. I've just tested from here and got exactly the same. TBH I'm not sure there is much we can do before the new skins for the site are released.
jelv
Fixes: 10
Re: Login Button
Try a CTRL+0 to reset your text size to normal.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
dejjones
Re: Login Button
My text size is set to medium.
If I select "smaller" the result is the same. If I select "smallest" or "larger" the results are as below.
jelv
Fixes: 10
Re: Login Button
1. You've switched from Firefox to IE - the CTRL+0 relates to Firefox.
2. Are you sure your screen resolution is 1280x1024? I've got more white space either side than you.
3. Have you modified any of the text sizes in your windows Display Properties, Appearance? The text of the menus in your screen shots looks bigger than it should on 1280x1024 resolution.
jelv
Fixes: 10
Re: Login Button
Time to move this to Resolved bugs?
Re: Login Button
Yep - not an issue any more.
