I thought that excessive blank lines had been sorted
Fixes: 38
Re: I thought that excessive blank lines had been sorted
@jaread83 - OK one more thought, what about reverse iterating the <div> tag looking at each <p> element, if this element is 'empty' it can be removed provided it is the last element in the sub tree i.e. the next forward tag would be the </div>, just a thought.
jaread83
Fixes: 78
Thats what my second bit of code is attempting to do by using the 'reverse' order working up the DOM. You will see that for each post it is attempting to start at the end and go back looking for empty paragraph tags. Once it reaches something that doesn't match the regex it should return false and then move on to the next post.
Unfortunately my code doesn't work so it needs something else.. I am just unsure what its failing on.
jaread83
Fixes: 78
I have added comments to demonstrate what it 'should' do...
    // find each instance of the post message on a page
$(".lia-message-body-content").each(function(){
// now within the post message, collect the p tags in reverse order $($("p").get().reverse()).each(function() {
// define context to the p tag var $this = $(this);
// check if the pattern matches <p>&nbsp;</p> if ($this.html().replace(/\s|&nbsp;/g, '').length == 0){
// remove if matches.. $this.remove(); console.log('found a match'); } else {
// don't do anything and stop the function if there is content return false; console.log('stop!'); }; }); });
Fixes: 38
@jaread83 - Well this works for me.
<html>
<head>
	<meta content="text/html;charset=utf-8" http-equiv="Content-Type">
	<meta content="utf-8" http-equiv="encoding">
	<title>Test</title>
	<style>
		.lia-message-body-content {
		background-color:red;
		border:1px solid black ;
		font-size: 18px;
	</style>
	<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.4/jquery.min.js">
	</script>
	<script>
	$(document).ready(function() {
		$(".lia-message-body-content").each(function() {
            	if ($this.html().replace(/\s|&nbsp;/g, '').length == 0) {
           			$this.remove();
            	else {
          	  		return false;
	</script>
</head>
<body>
	<div class="lia-message-body-content">
		<p>Blah</p>
		<p>&nbsp;</p>
		<p>&nbsp;</p>
		<p>Another Paragraph I want to keep</p>
		<p>&nbsp;</p>
		<p>&nbsp;</p>
		<p>&nbsp;</p>
		<p>&nbsp;</p>
		<p>&nbsp;</p>
		<p>&nbsp;</p>
	</div>
</body>
</html>
So as to why is doesn't work for you then, I don't know But you might want to fix the return false statement and put it after the console.log('stop') as that is unreachable.
jaread83
Fixes: 78
I will give this a try out on staging and see what happens. Cheers for sparing a bit of your time to help out with this.
jaread83
Fixes: 78
That didn't work and I think its becuase of the return false. It removes the empty paragraphs from the very last instance but skips over the rest. I created a jsfiddle here:
https://jsfiddle.net/659Lejgz/
Maybe its the for each loop, maybe it needs to be an array.. hmmm
jaread83
Fixes: 78
boom!
https://jsfiddle.net/659Lejgz/4/
Fixes: 38
Glad to see it's all working now, but are you going to install it?
Moderator's note by Adie (Dvorak) removed excessive white space.
jaread83
Fixes: 78
I can't put it up yet as there are a few other things on staging waiting to go up as well which needs to go through change management. I have implemented it on staging and it looks like it is all working. There is also an issue that if you quote someone who has empty paragraphs it carries over into the quote (very annoying!).
jaread83
Fixes: 78
scratch that, I just extended the function to include blockquotes too and it works for that as well (woohoo).
Fixes: 21
I shall go and play Wink
Fixes: 38
Of course the space was put there for testing! Tongue
Fixes: 21
jaread83
Fixes: 78
@Oldjim wrote:
@jaread83
https://community.plus.net/t5/General-Chat/H-D-T-V/m-p/1340819#M202879
Is a quote of the post with the problem
There are numerous lines with
<p>&nbsp;</p>
Just going through the threads that were mentioned in the latest update thread.
A fix for this issue will be pushed live today, you can view details of the fix on the update thread here. See the second and third item on the 'regular changes' section.
Fixes: 21
I've thanked your post above and will just test the fix out here ..... and then edit the post after to tidy up anything that needs to be.
Well I put loads of blank lines at the end of the post which got successfully removed from the "posted" post. I've left some above to show they correctly remain.
Above, I've now quoted part of your post and put some extra blank lines within the quote which should remain, and put some at the end which should get removed Wink
And that all seems to work perfectly as expected, so another one for @Oldjim to hopefully mark your post above as a fix Smiley
