Hyperlinks
NorthEasterner
Hyperlinks
How do you link a hyperlink to a text?
For example I wanted BBC.co.uk to the text 'here'  How would I do that using the hyperlink tool?  I was able to do it before but I've forgotten how to
Please don't use [ ] as the forum will confuse itself, instead use ( ) in replace of what you would actually use.
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
3 REPLIES 3
RPMozley
Seasoned Pro
Fixes: 18
Re: Hyperlinks
There you go NE, from your example:
HERE
Shows as below in forum:
HERE
That's RPM to you!!
NorthEasterner
Re: Hyperlinks
NorthEasterner
Re: Hyperlinks
Www.bbc.co.uk
HERE
