How do I remove FIXED label from my post?
jric
Just been to add to my thread and don't know how/why but it is marked as FIXED. As original poster is there a way to remove the 'fixed' label or a way to contact a moderator to get it removed so that I can continue the discussion?
1 REPLY 1
Fixes: 579
Re: How do I remove FIXED label from my post?
Go to the fixed post and click the 'Post options' dropdown. One of the options is Report to Moderator , ask them to remove the Fix
I'm guessing its this thread https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/FRITZ-Box-7530-as-DECT-base/m-p/204983...
I thought it 'odd' that it'd been marked as fixed !
