Forum search feature requests
On the "Advance search" page, can an additional search type be added,
where the results only show when ALL THE KEYWORDS are matched.
In addition, would it be possible to switch off the spelling auto-correction on the basic search ?
It is stupid entering exactly what you require, pressing search, only to find what you have typed has been auto-corrected to something irrelevant, then having to press the link to search for what you actually typed, and then still not getting the result which you know exists somewhere - which you can only find by going to Google and searching the forum with that !
Crazy2
17 REPLIES 17
jaread83
Fixes: 81
Re: Forum search feature requests
We can't change how the search works unfortunately. I can certainly put the idea to Lithium to include this extra field in a future release of the software.
HarryB
Fixes: 256
I agree with you on the auto-correct side of things, however in regards to the option for all the keywords, isn't that what 'With the exact phrase' does?
Or did you mean having the ability to enter multiple words and bring up threads that contain all the words, as opposed to an exact phrase?
 Harry Beesley
Unfortunately I don't know what the "exact phrase" is that I'm looking for, in a old forum post that I made several years ago, I only know the keywords and numbers which I would have used to describe a technical issue that I'm trying to help Bob Pullen with.
jaread83
Fixes: 81
If it's one of your own posts you can put your username into the left side to only bring back results from your own post history.
Well that sort of worked, but was still useless.
Doing what you said, I entered - "MyForumName  SearchKeyWord",
and what came back were indeed only my posts, but contained seven pages of results, of which only one contained my 'SearchKeyWord', and all the others were irrelevant.
Unfortunately the one correct result wasn't the historical result I was looking for - which I know does exist.
This is why I need this search to have a "Result contains ALL words" option !
jaread83
Fixes: 81
You don't need to put your username into the search bar. There is a username input on the left side of the advanced search page which will apply a filter to your search.
Anotherone
Champion
Fixes: 21
The whole search engine thing here is so clunky that it even makes our old SMF look good.
Various requests have been made -
  • expand the 'By Location' as a default setting
  • turn off fuzzy search - when searching for exact words/phrases - ie if searching for "Questioning" not to return results for Question, Questions, Questionable, etc.
to name but two.
HarryB
Fixes: 256
Just going back to this point:
Me and Chris have been having a dig around the settings and found that we can disable the spell-check on the search bar. So we've now turned that off.
 Harry Beesley
Anotherone
Champion
Fixes: 21
That'll be helpful thanks, I was going to comment that you can avoid the auto-correct if you are careful.
jaread83
Fixes: 81
Nice one on switching that off, should now give more accurate search results unless some users can't spell what they are looking for... what would be really helpful is that if a spelling error was detected, it would still search that phrase but also give a 'did you mean to search for <correct spelling>?'.
HarryB
Fixes: 256
Maybe one for Lithium to consider?
EDIT: Unless it already does.
 Harry Beesley
jaread83
Fixes: 81
Worth submitting an idea to their ideas portal me thinks.
Anotherone
Champion
Fixes: 21
Hey, I can now search for DLM without it auto-correcting to Dr Wink
jaread83
Fixes: 81
Already seeing some improvement then!
