Formatting of PM posts
Fixes: 241
When viewing PM (sent) posts the text is all scrunched up.  Looking at the CSS, I observed...
p{margin:0 0 12px }
In /skins/1311861/9a564793a1f6f10ae5bca9e7e2c69da3/plusnet_responsive_v2.css at plusnet_responsive_v2.css (1,9244)
Is there a coordinate missing here? Should it be ...
p{margin:0 0 12px 0 }
Hacking the CSS in debug mode making margin-bottom : 12px delivers a great improvement on readability.
3 REPLIES 3
jaread83
Fixes: 81
Re: Formatting of PM posts
Hi Townman,
CSS fills in the blanks and margin: 0 0 12px; will render the same as margin: 0 0 12px 0;
The p tags in the PMs are actually being set at a base level (overiding the browser default) via the following:
.lia-message-body-content p, .lia-message-body p, .lia-message-editor p, .lia-note-body p {
    margin-bottom: 0;
The above CSS is part of the Lithium CSS that I can't change, I have to override that stuff.
And for p tags in other areas - they are set individually like this (to override the above with my own css):
.lia-message-body-content p, .lia-message-editor p {
    margin-bottom: 0.5em;
So this can be fixed with a little bit of CSS, probably look to adding to the above CSS so its all the same.
jaread83
Fixes: 81
I have fixed this on staging @Townman. I have snuck it in with the changes I am doing to a missing js library CDN so I might be able to get this live later on.
Fixes: 241
@jaread83,
Thank you for the prompt fix.  I do wish similar hacks offered elsewhere could be snuck in so quickly.
