Compact design CSS for Plusnet Community
Anoush
Aspiring Hero
Fixes: 139
Re: Compact design CSS for Plusnet Community
This sort of reminds me of our old community forums.
I'm liking it, will install later. Thumbs_Up
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Fixes: 392
@jaread83 - thanks for this Jack, will install/have a play when I get home in January - I'm on hols atm and don't spend long on PC.
Mav
Fixes: 518
@jaread83
There seems to be an alignment issue when displaying fixed posts:
Forum Moderator and Customer
jaread83
Fixes: 81
Thanks for pointing that out, I have fixed this now.
Oldjim
Resting Legend
Fixes: 63
Does that require the code in Stylish etc, changing
jaread83
Fixes: 81
Yes. I have updated the pastebin links.
Mav
Fixes: 518
@jaread83 There seems to be an issue with the Compact Style where the text in the first line of a post overruns into the Post Options box whereby the Post Options drop-down menu is then not available for any of the posts within that thread (not just the current page). Turning off the Compact Style and all works fine again. (It doesn't affect the Thread Options Drop-down boxes)
Edit: It also seems to affect the Preview when posting a reply.
jaread83
Fixes: 81
Thanks for flagging this up with me. I had a feeling the upgrade would have borked my custom style skins. This is something I would need to do out of office hours so I will come up with a solution over the next few days Wink
Mav
Fixes: 518
No worries @jaread83. I simply turn off styles when faced with such a post and back on again after. A little inconvenience but nothing major.
jaread83
Fixes: 81
I have updated the links with updated styles. It's not perfect but it will work. I will be looking into integrating a permanent solution in the future.
