Behaviour of "mark as read"
- Feedback
- Community Site Feedback
- Re: Behaviour of "mark as read"
- « Previous
- 1
- 2
- Next »
10-03-2008 10:43 AM
10-03-2008 10:46 AM
10-03-2008 10:51 AM
Go to your profile, and then to the 'look/layout' settings page http://community.plus.net/forum/index.php?action=profile;sa=theme
Then select Show quick-moderation on message index as checkboxes
Then you will see the column of check-boxes, and you'll be able to mark the ones you choose as read.
10-03-2008 10:59 AM
And what is this: "Use quick reply on topic display"?
10-03-2008 10:59 AM
10-03-2008 11:07 AM
Its just that the only moderator actions available to you aren't really moderator actions after all.
Quick reply adds a box at the foot of each topic, so you don't have to open a seperate window to reply to a thread.
10-03-2008 12:49 PM
10-03-2008 1:14 PM
Quote from: James_H I suspect that Jelv has the option turned on in his profile, and nobody else posting here does.
That I do. I don't remember setting that option on - it must have been ages ago!
10-03-2008 4:34 PM
Quote from: James_H It means show the boxes that allow you to moderate the posts.
Why don`t you have a " Mark as Read " box anyway...? (OR, even change the present label in the look/layout to read what it is supposed to mean.....
As mentioned later on.... Who knows what that moderator gobbledegook means? If no one know, no one will tick it....
10-03-2008 4:45 PM
It does give mods a lot of other shortcut options, so I can only imagine that its an SMF naming convention thats a little kooky.
Heres the options that mods get:
Remove selected | Lock selected | Sticky selected | Move selected to: | Merge selected | Mark selected read
Its exactly the same on PUG too, and we use the same forum software there.
If Colin didn't know the option was there, then you are right, the rest of us have little hope....
- « Previous
- 1
- 2
- Next »
