Attachments in PMs
Attachments in PMs
I tried to search before posting but nothing was found using 'Attachments in Private', or the subject title, but anyway can't we add attachment(s) to Private Messages! Crazy3
24 REPLIES 24
HarryB
Fixes: 256
Re: Attachments in PMs
You can still insert images in to the message Smiley
Managed to get the second half of my sentence at the start in my test pm to you though Embarrassed
 Harry Beesley
Anotherone
Champion
Fixes: 21
Inserting images into PMs had stopped working before launch. There's been no advise that the issues has been (properly) fixed, but I have managed to do some test PMs with images in, but it's a bit hit and miss along with Preview of PM where you can lose what you've entered.
@Anotherone - With some help I managed to get this to work, but it only appears to support images but for now at least it works for me.
Fixes: 246
Back to the OP's question - given that write a post and write a PM uses the same components, why is there no ability to attach files to PMs in the same way that there is for posts?
is this one for you @jaread83?
jaread83
Fixes: 81
I can attach images to private messages without an issue but if its other things that need attaching like PDFs, XML, Word, Excel or anything other than images then I will need to raise a support ticket to include some kind of attachment to PM that will accept a wide range of file extensions.
Would you guys find this type of functionality useful for private messages? I think with normal posts you can attach files as an attachment just fine and they appear at the bottom of the message - this also helps mobile users attach files to posts.
If this is something you guys need I can add it to my feature list to get the ball rolling.
w23
Fixes: 4
You can't attach .pdf files to posts?  You can. Smiley
You can't attach .xls, .doc etc.
Call me 'w23'
Fixes: 246
Jack,
It would certainly present consistency of functionality.  For a use point of view, it would allow non-image objects to be passed privately to support staff.
Fixes: 246
We are discussing Private Messages - not posts, which does have this functionality.
jaread83
Fixes: 81
I have added it to my enhancement list as this functionality would be very useful.
@w23, as you have already proven - you can insert pdf's into the attachment box. I think the main concern is that users might want to send sensitive documents to plusnet staff to better help them over PM rather than in public.
edit: i am aware that the attachments are limited for certain file extensions. this can be changed if there is a real need to attach those types of files.
w23
Fixes: 4
Sorry, not paying attention.
As it stands, images can be placed in a message (not attached as files), could do with a file attach function please.
Call me 'w23'
w23
Fixes: 4
Ignore, multitasking is NOT efficient! Sad
Call me 'w23'
jaread83
Fixes: 81
I can always increase the scope of filetypes for attachments if neede - what file types do you guys use for file attachments on posts? it is currently set to only allow jpg, gif, png, jpeg and pdf.
I can set it so you can upload whatever you want but this could open the community up to malicious scripts so I am not prepared to do that! Cheesy
@jaread83 - Anything that's not directly executable would be my suggestion. Maybe with a caveat added to the message / post to remind the user to scan any attachments downloaded from this site regardless of source.
jaread83
Fixes: 81
I'm thinking...
all MS office documents
all image file formats
PDFs
Any others?
The caveat would need to be added to the FAQs about scanning downloaded attachments.
